Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: 93 Toyota 4Runner...
  1. #11
    Newbie Craigus's Avatar
    Aug 2005
    Australia Mate
    You didn't see this?
    System: PIII 1000, 512 MEG SDRAM, 40GB 2.5" HDD, D-Link Wi-Fi, Morex 80W PSU, 7" Lilliput.
  2. #12
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    Quote Originally Posted by Cris
    Sweet Greeny! You've been busy...
    Yes I have
  3. #13
    Aug 2002
    Quote Originally Posted by Resonant_Dream
    Hi Meddler, I just realized that we have the same truck just different name... I have two amps. in the storage compartments in the extended part of the cab. Where did you put the computer in the truck? Under the seat would be kind of combersome and unsightly, I was hoping to put it in with the subs but do you think the virations from the system would shake it apart? Or do you think the glove box would be large enough? What's your bulid up and purpose for your system (Media, GPS, OBD-I...)?
    Jeremiah
    Sub is in the storgae compartment under the rear seats on one side. I had to make it out of fibreglass to fit. PSU and HDD + fuse block is in the storage compartment on the other side. PC is in one of the storage areas in the side of the extra cab and the amps will be behind a custom rear seat cushion under the rear window. Haven't looked at putting the mobo in the glove box. I wanted to keep that for storage.
    In a truck that small, vibrations are always going to be a problem, but I don't think you will have a problem.
    purpose for the build. Well that is a long story. started off as just an mp3 player and got out of control. So just about everything.
  4. #14
    Jul 2004
    I too have a 4runner its a 94, same dash. I had to take the touch screen off to see the thing in the daylight. I mounted the same place, where the stock stereo is in the double din. I cut the case of the lilliput to fit and made a wood bracket to screw it too. Then moved my pioneer head unit down lower between the two brackets running up the center of the dash. I think if you get your windows tinted the glare would be cut down alot, but not much you can do about the front windshield. If you can get it recessed in that same spot it would help more as well.
  5. #15
    Aug 2002
    pics?
  6. #16
    Mar 2006
    hey meddler i have a 92 toyo pickup ex-cab, with basically the same set up. i have a sub in the rear under seat storage and i put the amps where the rear cushion i haven't fiberglassed the rear part yet i just have em mounted on the back wall for now, i was going to put the pc under the other storage but i may just put it under the center console after i get buckets i wouldn't mind seeing your set up. how big is your sub? i got a twelve to fit back there, a little tight but it sounds better than the two tens i had before. hit me back
  7. #17
    Mar 2006
    hello meddler? are you there? do you have any pics of your truck you would care to share and compare?
  8. #18
    Aug 2002
    sorry mate. have been busy with work and family stuff. I was not trying to ignore you.
    I have since sold the car, but I have pictures from the trial fit. I also have a radio surround to fit a 7" lilliput that I would like to get rid of if you are interested.
    link here
  9. #19
    Mar 2006
    do you have any after pics
  10. #20
    Aug 2002
    for some reason, the pics didn't upload properly. I have some finished pics, but mainly of the side panels. I had it all in there and didn't take any pics before I pulled it out. The amps were only mounted on a board in the back and was never finished.
    Have another look at the link and there should be some more pics now. The folder of last progress pics should be what you want to see.
  1. 2004 Toyota 4runner
    By rando in forum Show off your project
    Last Post: 11-29-2011, 09:08 AM
  2. Finally, 2004 Toyota MatrixPC is ready for primetime
    By MatrixPC in forum Show off your project
    Last Post: 11-28-2009, 05:50 PM
  3. Replies: 17
    Last Post: 07-27-2007, 06:05 AM
  4. 2000 Toyota 4Runner
    By mookie in forum Worklogs
    Last Post: 10-19-2005, 01:55 PM
  5. Toyota Hi Lux Surf (4Runner)
    By sdl in forum Show off your project
    Last Post: 04-04-2005, 03:13 AM
