Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Astra MK4 install
    Sep 2005
    Astra MK4 install
    Just finished installing my touch screen and mini ITX car pc.
    I am more into the car side of things and my mate is the computer brain side of things.
    Thought I would post some pictures of it all installed
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    looking good, excellent finish on the dash. what products did you use?
    can you operate the HU without the front flipping round? that would make it nice for when not using the radio.
    Sep 2005
    Screen was fibreglassed and fillered in then rubbed flat and sprayed at a bodyshop with plastic undercoat then normal paint as the top coat.
    My headunit is used as the amp so it needs to be on for that
    Jul 2005
    Want to do something similar in my Astra only I'd prefer to have the screen lower and leave the air conditioning vents above the screen. Is there any issue covering the air conditioning vents up? Have u blocked air from coming out or do you let it blow behind the screen??? I imagine if you let it blow over the screen you would have condensation issues on the circuit board.
    Tainted Love Cris's Avatar
    Romania
    That looks great!
    Where did you put the computer?
    Sep 2005
    The centre vents only blow cold air so I wasnt too bothered about loosing them. You can also use the side vents and direct them at you if you feel the need but so far I havnt needed too.
    To block the vent I used some dense foam that I cut to shape and pushed into the hole so it was a tight fit.
    Because the PC is so small and runs nice and cool I mounted it inside a first aid box and mounted it in the standard position.
    I still need to tidy the wires so you cant see them as easy but this is what its like.
    Romania
    Sweet ideea. Is that an Astra Sedan?
    Sep 2005
    Nope.
    Its an Astra coupe
    Romania
    Quote Originally Posted by Leegsi
    Nope.
    Its an Astra coupe
    Wow, and a sweet looking one too.
    Did you do anything to the bonnet? It looks diferent...
    FLAC djmickyg's Avatar
    Feb 2004
    very nice car.
    ive never seen the astra coup is australia. we only have the liftback.
    yeah whats with the bonet?
    and nice screen install
  1. 2002 Montero Limited Install...
    By Squid in forum Show off your project
    Last Post: 10-06-2009, 04:41 PM
  2. XC90 Install - am I the first??
    By klokman in forum Worklogs
    Last Post: 02-13-2007, 01:12 AM
  3. 94 Jeep Grand Cherokee Install
    By jamiewhittingha in forum Show off your project
    Last Post: 08-02-2006, 02:02 PM
  4. Phase 2 Peugeot 306 Install
    By 306carputer in forum Worklogs
    Last Post: 02-10-2006, 09:00 AM
  5. How should i install this?
    By jnusaira in forum General MP3Car Discussion
    Last Post: 08-13-2004, 04:03 PM
