Results 1 to 10 of 16
Thread: Renault Clio 2000
    Newbie Stooboy's Avatar
    Aug 2005
    Scotland
    Renault Clio 2000
    Ok here is some pictures from my recent, Very first carputer install. It went mainly ok and I have to thank these forums for all the invaluable information that was provided so that I was able to pull it off!
    Before
    Still Before
    Mid Gutting
    Gutted
    More Gutted
    Dash Fab
    After
    You can get more pics from the link in my signature, Im currently having problems with my ISP and will be moving to a new one soon, so they may take the pics offline when I move as im only using my ISP's free hosting to hold the pics.
    Cheers
    Stooboy
    Reanult Clio 2000
    Carputer Progress = 99.99%
    Pics of progress Gallery
    Variable Bitrate 4u2n's Avatar
    May 2004
    Denmark
    Nice setup with the screen,
    buth the laptop take the setup down again
    you shut continue in the same stile as you do on the screen
    Plan for project = 100%
    Part the project. = 100%
    Built...................= 99%
    Finish.................= 99%
    Install ...............= 99% -50%
    Ditail at 4u2n.dk
    Here
    Aug 2005
    Scotland
    Yeah your right,
    The laptop has let the project down, the reason being is that bit was rushed, as once the car was tottaly gutted I kinda paniked!!!, and was like rite the laptops going here, and chopped it out quickly, rather than wait for my friend and his dremmel, and then put the dash back in the car so it was drievable again, there are still a few bugs needing ironed out and I think I will revisit the laptop section and tidy it up.
    Reanult Clio 2000
    Sep 2005
    Germany
    omg!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    this is a closed laptop under the..hmm whats that named ?
    is it only taped?
    but the screen is good big
    Jul 2005
    Ontario
    where in the hell are your vents now ? how are u going to let air in for the mid section of the car? im not saying its a bad fabrication because i have not done it my self or tryed it but u should of fabricated the whole dash and left the vents on and moved the climate controll hu in the trunk or fabricated it in somewhere in the dash...
    Jul 2005
    Ontario
    btw if you did not cover the vents that used to be where ur school is now in winter its going to over heat and probably die...
    Aug 2005
    Scotland
    Quote Originally Posted by weirdmeister
    is it only taped?
    its an IBM T21, I got it cheap from ebay as the screen that was on it was faulty, I put a sheet of metal in place of the faulty tft and bolted that to the underside of the dash. The tape is there as an interm fix due to the fact there should be two catches on the lid to keep it shut, unfortunately I never realised until it was bolted in that one of the lid catches was missing and the bottom half of the lapop was rattling so the tape is keeping it in place for now.
    I can remotely turn it on and off from the origional radio stick control on my steering wheel I had hoped to control the volume from that as well but I buzzed out the rubber membrane wrong, so the volume up and down equate to w and / on the keyboard :|
    Reanult Clio 2000
    Aug 2005
    Scotland
    Quote Originally Posted by Kiriller
    I blocked the vents with foam, and put some strong tape over the top. As a result the other vents are stronger.
    The way I look at it is I dont remmber using those vents very often and there are plenty of other vents in the car.
    Whats the first thing you do on a frosty morning when you get in your car????
    You turn the vent dial to windows and get all the hot air beltching out to defrost the windows... Usually by then the car is quite toasty.
    I did have concerns about loosing the vents at first but plenty of other people on these forums have removed the vents in favour of a screen.
    Reanult Clio 2000
    Tainted Love Cris's Avatar
    Romania
    That's not an ordinary Clio anymore. Good job. Couple of wuestions: Why didn't you mold the buttom part of the screen too? Too bad you had to pull out all the dash only to get that panel out...What did you use to cover the vents?
    btw, is that a Clio Symbol?
    EDIT: just seen the vents picture...
    That would've been a little extreme on a Clio...not to mention it wouldn't have looked good.
    I've lost the central vents myself, and I really don't miss them...
    Aug 2005
    Scotland
    Quote Originally Posted by Cris
    Good question, I havent decided what to do about the bottom part of the screen (or the top), I have a cunning plan up my sleeve I've not looked to see if anyone else has done it BUT, I was thinking of using the vents I cut out, and making a fake front! So that it looks like a normal clio again i.e. I put the fake front on the screen when I leave the car unattended and maybe get a fake front facia of a really crumby radio cassete to stick on it too (or butcher the one that I took out of it but I was hoping to sell it on ebay).
    Quote Originally Posted by Chris
    Someone posted on my gallery comments that I didnt need to take the whole dash out to get the vents out, however try as I did to do that it, I couldnt see a way round it, even with the dash out it was difficult to remove the vents because it was rivited in and also had a lot of the plastic melted onto the main vent conduit/trunking.
    It all came good in the end.
    Quote Originally Posted by CHRIS
    Some antistatic foam that came with a dvd drive I got, and this heavy duty tape I found in my dads garage.
    Clio symbol ? erm dunno were that is, its not intentional anyway
    Reanult Clio 2000
  1. Renault Clio Help!
    By nathan2oo3 in forum Newbie
    Last Post: 08-12-2005, 08:39 AM
  2. Installing Windows 2000 Pro on a 1GB Microdrive
    By JeremyM in forum WinNT Based
    Last Post: 05-07-2005, 10:56 PM
  3. Replies: 3
    Last Post: 12-02-2004, 03:48 PM
  4. Windows 2000 Lite?
    By storm in forum Software & Software Development
    Last Post: 03-25-2004, 06:05 PM
  5. speed up win 2000 boot time
    By more mods in forum Software & Software Development
    Last Post: 06-09-2003, 12:05 PM
