looks good. Could you give us some detail on how you mounted the screen - what's holding it there?
This is my first car pc. The Pt cruiser is a challenging car, particularly since my goal was an easy return to stock appearance. I purchased a bezel on Ebay, cut out the space for the monitor, and used bondo for a pretty integrated approach. I moved the window switches to the lower console, (pictures coming soon) moved the open/close knob to the outside of the vents, and put the computer under the front seat. I also mounted a 120volt outlet in the console and put the inverter behind it. Ask me questions if you want, I've never posted here before, so enjoy.
I think you should remove the factory vents all together and flush the screen right in. as it is, its very functional, but it looks like you cut the vents with a saw and stuck the screen in there.
