Page 16 of 17 FirstFirst ... 67891011121314151617 LastLast
Results 151 to 160 of 167
Thread: Project CompuMach: 2004 Ford Mustang Mach 1 - Total In-Dash install complete!
  1. #151
    Maximum Bitrate pyros's Avatar
    Mar 2004
    Toronto, Canada
    http://www.machwon.ca/box
    there are some preliminary pics... i have the fleece resin'd and the first layer of fibreglass is on... gonna work on it some more today... i'll try to get some more pics
    Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
    Install Status: DONE
    My XM FAQ
  2. #152
    Low Bitrate ibanez737's Avatar
    May 2005
    Lookin good man...make a couple more 10" ones and send them my way
  3. #153
    Mar 2004
    Toronto, Canada
    Haha.. ya right.. I don't ever want to do this again. It's such a pain in the ***.. hopefully it'll be worth it in the end
    My XM FAQ
  4. #154
    May 2005
    Hey, none of that negative attitude, the mach might hear Keep us updated
  5. #155
    May 2005
    Giving a bump to the mustang crew, had to pull this one up for some reading. Still waiting to see those sub enclosures finished up Mr Pyros. Also it was rather funny seeing how noob I was about a year ago. Thanks for the patience on your end, Pyros.
  6. #156
    Mar 2004
    Toronto, Canada
    Everything is out of the car right now... waiting on some new parts... power supply went kaput Think I'm gonna try something different this time.... will post updates soon...
    My XM FAQ
  7. #157
    May 2005
    Uh oh...hopefully the new install works out better. Got any ideas about the direction you're thinking of going?
  8. #158
    Mar 2004
    Toronto, Canada
    Not too sure.... gonna try a few different things and see what i like... one will be redoing the existing radio bezel b/c the bloody thing cracked on the edge where the screen meets the bezel (thanks bondo!). Might try to make a mould of the bezel as it is now and take it from there... we'll see.. lots of options :P
    My XM FAQ
  9. #159
    Constant Bitrate Homebrew's Avatar
    Maryland
    Just too throw in my $.02 pyros, I'm in the process of re-doing my cobra's bezel for the same reason. This time around I decided to go the duramix route. Right now it looks promising, but if you decide to try duramix, do yourself a favor and opt for the 4041 instead of the 4040 that is often recommended. The 4041 is the same as the 4040 except it has a a longer work time. 4041 has a work time of 2 minutes where as the 4040 has a work time of only 50 seconds. That added time will allow you to shape it a little more to minimize sanding. Sanding this stuff is a bit harder than sanding bondo IMHO, so keeping it to a minimum is a good thing. So far I really like the duramix, but it is a little trickier to work with than bondo. Also a little expensive if you opt to buy the dispenser instead of rigging one of your own. Just some food for thought if you were considering it.
    I also thought about repairing my last bezel and then making a mold of it and reproducing it, but be warned, it's a costly proposition. You'd have to make a 2-part mold and because of the intricate shape, it would actually take alot of material to make the mold. You could keep the cost down a little by removing the vent ducts before molding though. That way it would be a shallower mold, thus significantly reducing the material needed. If you could find enough demand for premade bezels though it could pay off. Again just my $.02.
    -Kevin
  10. #160
    Mar 2004
    Toronto, Canada
    Thanks for the info Kevin. I'll definitely look into the duramix stuff. I have somewhat ignored it since my install was done.. but it looks like that's changing now
    Thx,
    Chris
    My XM FAQ
  1. Citroen Berlingo 2004 complete install
    By skotte in forum Show off your project
    Last Post: 05-07-2005, 11:30 AM
  2. Replies: 21
    Last Post: 01-27-2005, 05:37 PM
  3. Replies: 11
    Last Post: 01-02-2005, 08:33 AM
  4. Replies: 16
    Last Post: 10-10-2004, 10:52 AM
