Agreed 100% , black and red goes good together.
BTW pyros, I think you have the best looking mach I've seen. That color combo and the rims just go perfect together. Major props on your setup as well. I'll probably have more questions in the future![]()
ibanez: thanks man! and feel free to ask questions, i'd be glad to help. btw, what year/model stang do you have?
kevinlekiller: thx!
Is this the harness you have pyros? http://www.partsexpress.com/pe/showd...number=265-790
2004 GTback when it was stock
ibanez, its pretty much the same but ford change the connector shape over the years so you have to be careful what you get. if you have a 2000-01, that will be fine. but for any other years, make sure you get the proper application. get a metra wiring harness, you can't go wrong. check out their site at http://www.metraonline.com/ and find the tech support phone number. call them and ask them for the exact model number for your year/model (most dealers tried to sell me an '03 harness saying it would work, which it wont!!! ford changed the stupid harness from 03 to 04).
So, I'm curious how you have this wired. You scrapped the factory headunit correct? If not, I could make sense of it but other than that I'm clueless lol. EDIT: I see you have the 2004 so what part number did you end up with? Also, do you know what paint your friend used specifically? Like Brand and a number? Sorry for all the questions, you're being a huge help though.
Not sure what the part number is, i'll see if i can find the package for it but i doubt it. your best bet is to just call their 800 number.
i scrapped the factory hu. computer goes in dash, usb cable from computer to trunk. in the trunk, usb cable to sound card. from the sound card: stereo-to-rcas cable to the amp to power highs, other pair of rca's from soundcard to front of car to plug into wiring harness. from the opus, the 12v accessory wire spliced into 2: one to connect to the wiring harness to turn on the factory amps and one to the amp in the trunk. thats about all you need for sound
Hey pyros, what GPS receiver are you using. I can't get mine to work from inside the car so I have it mounted outside, it works great there but kinda wanted inside the back window. I don't want to wait for an ******* to rip it off.
Progress: |##########| 99.99%
- Tweaking and enjoying!!!! Never really done.....
-= MachPuter Project =-
-= MachPuter Project Worklog=-
tip: your trunk lid is fiberglass. mount the GPS to the inside the of trunk lid, it'll work like a dream.
works perfectly for me in my 03 GT and it's invisible. same thing goes for the XM antenna.
Pyros, I'm trying to make sense of this, I'm more a computer guy than an audio installer lol. So, idk if your wiring harness is like this, but the one i linked above is two pieces, one that has the ground 12v and speaker outs and another with the RCA's and some other stuff I don't remember. So, pretty much just connect the RCA's from the sound card to the wiring harness RCA's and then the RCA harness is somehow wired to the second piece of the harness to make the connection to the other 4 speakers? EDIT AGAIN lol: I just took a look at my wiring harness and noticed that it has the RCA's and the amp power/grounds on it and the other harness has all the rest. So power to the amp and ground the amp on that harness and connect the RCA's to the sound card. What do I do from there? It seems I have it all drawn out and figured except on how to get the audio signal to the amps for the four 5x7's from the RCA/wiring harness steps.
EDIT: I'm trying to compile all my questions at once instead of jumping around so much, I keep getting spur of the moment questions while I'm at work. I'm going the laptop route so without the opus, would I just wire something up through the battery or tap into the accessory power/ignition power?
