Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
Thread: New Install '02 BMW 330Ci
    Mar 2001
    Baton Rouge, LA
    Hi guys,
    Been lurking for a while and wanted to thank everyone for the great info here.
    Just got my carpc installed and thought I'd post the few pics I took.
    Stats are:
    Xenarc 700TSV
    P3-1Ghz
    ASUS CUV4X motherboard
    GeForce 5200FX
    SB Live!
    Linksys Wireless-G PCI
    120Gig HD
    Opus 150
    BU-303 GPS Mouse
    Peripheral SVEN4
    XM Direct
    iGuidance
    Roadrunner with MC1.0 skin
    HU was removed and AC controls moved down. The trim piece for the lowered AC controls is 51 16 7 001 408.
    I used gork's how-to on fabricating a bezel here. This was my first time working with bondo so it was a great help.. Thanks Gork!
    I ran into problems with the first computer I put in there. Initially, I had a AMD 1.33Ghz with a MSI K7T Turbo motherboard that I had previously been using as a MythTV box. That was what I was using during the OS install and playing with frontends while I waited for the LCD and stuff to come in. Everything works fine with it while plugged into a 400W AC/DC power supply, but when I plugged it into my Opus, the computer would boot.. start loading windows... then either just lockup at a black screen or reboot itself over and over. So after some choice words, I sat down and had some wine. Later that evening, I decided to try to underclock the processor to see if that would help (thinking it might be a power issue). I clocked it down to 1Ghz and bam.. it boots right into windows and everything worked perfectly!... until a little bit later when I was driving it decides to reboot itself. After some googling, I see that AMDs pull a crapload of power compared to Intels. So trying to keep the costs down on the computer for now.. I dig around and find a P3-1Ghz and motherboard sitting in the closet. Install all that and I haven't had a problem yet. Speed is sufficient and bootup time is decent. I haven't timed it yet, but once I set it to hibernate, it boots up before I get out of my driveway in the morning.
    I guess I need to add up my power to see how much room I have to spare. I still want to add bluetooth support to interface with my Sony S710A and Blackberry 7520. I'm also tossing around the idea of getting one of those cell data cards and dropping that in.
    ToDo:
    Bluetooth Support
    iBus integration (waiting for kit)
    Optimize OS
    Run cable for a USB hub in console ashtray
    Fabricate plate in front ashtray for valet switch/reset button
    Fabricate a cover in trunk to protect/hide computer.
    Here are a few pics:
    The Car..
    Foam sprayed over Xenarc front bezel to shape..
    First glob of Fiberglass Bondo applied. This was my first time using it, so I wasn't really sure how to put it on. After this initial application, I realized that by "combing" it down, it was easier to clean up afterwards. Also, I only had about 3-5 minutes to work with it once mixing the cream hardener in.
    Primed, and SEM texture painted..
    Bad, dark pic of the install. I'll take a better pic later today with my friend's Canon SLR..
    Just realized I didn't take any pics of the trunk. I'll do that later also.
    Here's a link to a gallery with a few more pics
    Takes it in the Rear kevinlekiller's Avatar
    Dec 1969
    Where the penguins and polar bears live.
    Looks nice , pics of pc?
    gbh
    gbh is offline
    Constant Bitrate gbh's Avatar
    Oct 2005
    Massachusetts, USA
    Looks great! Nice job on the bezel!
    Constant Bitrate CornToeGoblin's Avatar
    Dec 2004
    Texas
    man the running lights on those new beamers are killing me. i wish i had a good job to afford one like that
    2008 Civic... Sound system... then carputer install...
    WORK IN PROGRESS
    If you look at my avatar closely, you can see a chick with two big knockers....
    Newbie Sir Posts A Lot's Avatar
    Oct 2005
    I like the body kit you put on it, as well as the computer.
    Jul 2004
    Are you saying that you just covered the Xenarc frame in spray foam, trimmed that down, covered the spray foam in bondo, sanded, then painted?
    Is that very strong? I'm thinking that the spray foam isn't strong enough to give the bezel a good sturdy base. Correct me if I'm wrong
    In any case, it *looks* superb! Good work!!!
    Oct 2005
    I knew that looked Familiar. Thanks for re-upping my interest in this. Now I gotta go spend all that dough
    Mar 2001
    Baton Rouge, LA
    Jackboot,
    I just used the foam for the initial shaping, and ended up cutting it all out anyway. The foam definately isn't strong enough to provide support. After getting the initial shape, I started cutting the foam out and refilling with the fiberglass bondo. On the skinny parts, I just broke off the bondo/foam and put solid bondo there. So the whole bezel is a core of fiberglass bondo with a thin coat of regular bondo to fill the little holes.
    ccla.. get the mini in that f-150.
    2006 Nissan Titan LE Truckputer
    [I]No installation thread yet[/I
    2002 BMW 330Ci Steel Grey Metallic *Sold!*
    Installation Thread
    Mar 2001
    Baton Rouge, LA
    Just took a few pics.. trunk isn't done since I still need to build a wall or something to protect everything in there. I figure once this computer dies, i'll probably go Mac Mini or MiniITX.
    iGuidance.. still haven't done any mods to it.. just regular iG..
    XM on MC1.0 skin..
    New pic of car
    more pics Here
    Installation Thread
    Tainted Love Cris's Avatar
    Romania
    Sweet install. That texture paint is really nice!
  1. BMW Z3 2.8 Roadster Install
    By regal in forum Show off your project
    Last Post: 12-12-2007, 03:24 AM
  2. XC90 Install - am I the first??
    By klokman in forum Worklogs
    Last Post: 02-13-2007, 12:12 AM
  3. 2001 BMW E39 - fully integrated Carputer
    By tsingsu in forum Show off your project
    Last Post: 05-03-2006, 04:51 PM
  4. 2004 Bmw 545 Install
    By turbodman in forum Show off your project
    Last Post: 03-01-2005, 01:52 AM
  5. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 02:16 AM
