Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: 2003 Ford Falcon BA (Australia)
  1. #11
    Newbie bob^'s Avatar
    Jun 2005
    Geelong - Australia
    It's fine. Havn't tried it out in sunlight though yet as its still a work in progress.
    jaytyn, I made the shroud myself from a piece of 9mm mdf, which had a cutout that fits the screen, and then a piece of 3mm mdf over the top which has the cutout for the viewable part of the screen
    2004 Ford Falcon XR6
  2. #12
    Newbie jaytyn's Avatar
    Oct 2005
    Melbourne Australia
    There is this company: http://www.asllogistics.com that can upgrade the standard "green" lcd to a TFT colour jobbie as shown below for $1100. The only problem is that it will not be touch screen. I guess I can probably try and get a touch film. but the problem is the TFT will be composite in...
    ANy ideas... I really want an integrated solution and this sounds like the best way based on the BA Falcons design.
    From this:
    To This:
  3. #13
    FLAC NiN^_^NiN's Avatar
    Aug 2004
    Australia, Melbourne
    Why not just get them to mod the system and have your vga lcd installed instead then all you have to do is switch the signal from VGA to RCA 1 so u can change the temps etc
    This way the VGA lcd is installed
    Problem is do they use a 5" or 7" LCD? i think they use 5" i would ask them to see if they could create a bezal for a 7" screen and do the mod for composite output.
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
  4. #14
    Aug 2005
    how do u find the screen you currently have? what resolution do you run on it? i'm just personally wondering if i should pay basically twice as much for a lilliput over one of the ones you're using...
  5. #15
    Jun 2005
    Geelong - Australia
    I was going to use my factory screen but gave up on it in the end. The screen is approx 6" from memory
  6. #16
    Oct 2005
    Melbourne Australia
    I found the factory screen can support vga @ 15khz.
    Zedevan, the cheapo screen I have works a treat, I have no worries seeing it during the daylight... I do have tinted windows though...
  7. #17
    Aug 2004
    vga? u sure its not RGB at 15khz?
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
  8. #18
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    I dunno much about the technical details of the displays, but isn't 15khz a bit high? As the xenarc is only refreshing at about 60hz...
    Fox Mulder
    2004 Toyota MR2
    Modified Intel Xeon E5450 3Ghz Quad Core 2GB RAM 160GB SSD M4ATX Xenarc 700TSV TS Toslink Audio BU353 DiNovo Mini Car2PC ODBII Bluetooth HF 16x2 Character LCD
  9. #19
    Oct 2005
    Melbourne Australia
    This is the email I got from the supplier:
    Yes it is possible to connect your car PC directly to the TFT
    screen although you may require special software when booting up to change
    display to 15khz.(Cannot guarantee this will work as is depends on the video
    card) Otherwise hooking up to RCA composite can be done.
  10. #20
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    I agree with fox... 15khz is a little high. You you happen to know anyone who works at ford that can check what type of screen it is for you?
  1. 2003 Ford Ranger FX4 Install (Lots of pics)
    By tbird2340 in forum Show off your project
    Last Post: 10-12-2009, 11:21 AM
  2. BA Falcon
    By jaytyn in forum Fabrication
    Last Post: 07-21-2008, 01:13 AM
  3. Carputer install in the Ford Fiesta 2003
    By skyflyer in forum Show off your project
    Last Post: 07-08-2006, 11:41 AM
  4. Possibly FS: 2003 Ford Ranger FX4 - LOTS OF MODS!
    By tbird2340 in forum Classified Archive
    Last Post: 07-05-2005, 11:59 AM
  5. 2003 Ford Mustang GT
    By tj!2k4 in forum Worklogs
    Last Post: 03-05-2005, 03:42 PM
