Page 7 of 10 FirstFirst 12345678910 LastLast
Results 61 to 70 of 100
Thread: '98 Audi A4 2.8 Install
  1. #61
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Quote Originally Posted by Ski85
    Hey everyone,
    i was thinking about buying a used 98 audi a4 1.8t quattro. i was wondering if any of you that have one can give me some info on them. ive heard quite a few bad things and some goos i was wondering if its worth even getting. Any info would be greatly appreciated.
    I haven't had any problems with mine. just wished I would get better gas mileage though.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  2. #62
    Variable Bitrate 3g Jester's Avatar
    Nov 2005
    wow thats hot. i like the install on the dash and the subs especialy. how did you learn to do the fiber glass housing for the subs? im sure its not bondo...reading online or someone show you the way?
  3. #63
    Low Bitrate che420's Avatar
    Feb 2005
    charlottesville VA
    always get an audi with a warranty!!! no warranty no car. i've had two so far and the first one saved my life but fixing them......whoa!!!
    ...you know, that guy...
  4. #64
    Dec 2003
    New York
    Quote Originally Posted by 3g Jester
    no the subs are not bondo. how long would that last?
    Thats was the first time I worked with fiberglass. I just followed a couple of online tutorial. Its a little hard to work with, but you get used to it after a little while.
    Oh, just a piece of advice to anyone who's going to be figerglassing. NEVER sand fiberglass while wearing shorts.
    I learned the hard way.
    Installed
  5. #65
    Oct 2004
    NY
    bet you were itching for days great job on the screen... love the slot load... looks real nice...
  6. #66
    Dec 2005
    Question about my own Audi
    Great Install by the way. i have the same exact car as you, color and all. i started purchasing things i'll need to do a carputer like the one you have. right now i'm not sure how i'm going to make it all work with the factory speakers or if it can even be done. so far all i have bought is a touchscreen for the front and a Dell Laptop with all the best already installed, the screen was broke so i got it for a good price. If you know what i'll need to incorperated the laptop into my factory system and remove the factory head unit i would greatly appreciate it. Thank you
  7. #67
    Dec 2003
    New York
    Currently, I'm running all factory speaker expect for the subs. I'm using an audigy usb soundcard that is connected to a 4 channel amp. Then I connected all the speakers to the amp. I just connected the wires from the amp directly to the speakers. One of the rear speakers have a small amp connected to it, you going to have to connect the wires after that small amp.
    For the front speakers I took the easy way out. I just connected the wires from the amp to the factory wiring harness that connects to the stock head unit. I just tapped into the wire that connect to the front speakers. I didn't want to have to bother with crossovers and **** on the factory speakers. Plus there's something weird with the driver side speaker. Can't remember exactly what but it has to do with the factory phone in the car. But I did leave plenty of extra wire behind the dash for when I want to upgrade the stock speakers, I don't have to rerun more wire.
    any other question let me know.
    Installed
  8. #68
    Dec 2005
    Install
    Hey thanks so much for the information, i'm not too up to date on computer tech and if i knew someone to do it i would just pay someone to make one for my car. but haven't found a source for that and since i'm really interested in putting one in my car i figured this was my only way to go. i haven't looked into it but the sound card you said you used. Does that just have RCA outputs that would plug right into an amp? Also Will the soundcard be installed into the laptop or will it be external. Oh and what is that slot below your screen. Is that a CD/DVD slot and if so what model is it? THank you so much for your help. If you want to email me directly its blkcivsi23@hotmail.com
  9. #69
    Dec 2003
    New York
    Quote Originally Posted by blkcivsi
    where are you located?
    Yes, but it only has 2 outputs, so I used a splitter to make the 4 so it connected directly to the amp.
    external
    yes, its a cd writer/dvd burner. Its a full size pioneer slot load drive, can't remember the model number. But I would not suggest you use this model if you will be placing it below the screen. It will be VERY VERY tight, a pain in the ***. I had to use a converter for the pins in the back to make it fit, But I dropped the drive last month and broke so I'm looking for a new slim drive which will hopefully fit much easier.
    Installed
  10. #70
    Dec 2005
    thank you
    If i knew that there were people that where so willing to answer questions and help out i would have tried this a while ago. The last question i have is what model soundcard you used and what software do you use to run everything. MediaCar, Mediaengine? and is there something you prefer. I'm from philadelphia. Thank you again for everything.
  1. 2000 Audi A4 1.8T Quattro
    By cdevelasco in forum Show off your project
    Last Post: 05-01-2006, 09:14 AM
  2. My 1997 Audi A4 install
    By StutterinJ in forum Show off your project
    Last Post: 06-12-2004, 12:51 AM
  3. Replies: 15
    Last Post: 05-24-2004, 12:47 PM
  4. Audi A4 install - LCD finally customed into dash
    By brrman in forum Show off your project
    Last Post: 10-07-2003, 11:47 AM
  5. Audi A4 Dash Install Pics
    By surfer6262 in forum General Hardware Discussion
    Last Post: 08-07-2002, 04:14 PM
