Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: VW Passat '97 CarPC
  1. #21
    Tainted Love Cris's Avatar
    Romania
    Yeah, this is a fantastic skin indeed!
    I like it more without the lines in the main menu. And yeah, I was talking about the bevel, if you could tone that down a little bit, it would look better I think.
    And, you're definatly right about the ffw botton, it makes a lot of sense.
  2. #22
    Variable Bitrate proTONEd's Avatar
    Jun 2004
    Belgium
    I have made a few variations for the menu:
    1) Bevel for the menu items toned down, lines for items removed, bevel toned down for the player controls as well.
    2) added "1", "2", "3","4" intended as a shortcut to start applications
    - some comments please -
    3) re-added some bevel effect to the bottom buttons for the player.
    I feel there should be some contrast (but not also too much) between the middle part of the screen and the bottom. They are functionally different and you should get a hint of that be just having glanced at the skin.
    - don't mind the "1", "2", "3","4" in this example -
    A little note: I don't want to change my original concept too much
    Why is it drug addicts and computer afficionados are both called users?
    Currently : Audi A6 - no install
    Second install : VW Passat '97 CarPC
    First install : '87 Audi 80 CarPC
  3. #23
    Romania
    Quote Originally Posted by proTONEd
    Much better! You're right about the contrast on the upper/buttom part.
    This is so close to perfection now. Only thing is those fonts...how about a regular Arial, or a Bookman Old Style?
  4. #24
    Variable Bitrate Frigor's Avatar
    Aug 2004
    Faenza, Italy
    dude... what kind of vis is this?
    BMW E36 Project [ =======§== ]
    Hardware:
    Lilliput 7" Touchscreen - Epia M-10000 - HQCT 1.0 FM Radio - 2.5" 80Gb - USB GPS
    Software:
    FrodoPlayer 1.10 & MapMonkey with FriBruMet Skins by Frigor.
  5. #25
    Jun 2004
    Belgium
    Quote Originally Posted by Frigor
    @ Chris
    Thanks for the comments.
    Maybe I'll try some other fonts today or maybe tomorrow. I'll see how much time I have on my hands.
    @ Frigor
    I found the VIS on the net somewhere. A french site I believe.
    I still have the setup file but it is 286kb, too big to add here in this post.
    The filename is : equalizers-setup.exe. I don't kkow if it helps.
    I'll see if I can recover the link from somewhere.
    I have added a zip-file to the post. If someone would be interested to program his or her own visuals for Mediaplayer, it might come in handy.
    Attached Files Attached Files
  6. #26
    Jun 2004
    Belgium
    Guess what... I found the link for the visualization.
    http://lestourtereaux.free.fr/equalizers/
  7. #27
    Jun 2004
    Belgium
    Had day off from work today, so I dug up my skin once again.
    A little remark: it seems that Frodo uses the slider that is used as the trackbar slider in the "player". That is the the reason for the up, down and scrollbutton being all the same arrow.
    This is the result:
  1. '97 VW Passat Install
    By BenG in forum Worklogs
    Last Post: 11-28-2011, 10:26 AM
  2. 2001 VW Jetta CarPc Install
    By *Glow* in forum Show off your project
    Last Post: 03-27-2008, 03:00 PM
  3. VW passat antenna help
    By Cheekz185 in forum Car Audio
    Last Post: 10-12-2005, 06:31 PM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 02:19 PM
  5. CarPC in 2003 Passat
    By Alric in forum Show off your project
    Last Post: 01-24-2005, 02:26 PM
