Results 1 to 6 of 6
Thread: Golf III CarPC by Alcool_Puro
    Newbie alcool_puro's Avatar
    Oct 2005
    Golf III CarPC - My project.
    - Epia V800
    - Power Supply 80w
    - HDD 80Gb
    - SD-Ram: 250mb PC133
    - TV Tunner
    - Touchscreen 7'' MM 400
    - GPS: NL-202U USB
    - Antenna Wireless DWL120
    My project is a pc build on a plexiglass case, designed to be easily
    removed and used at home connected to a simple 12v source.
    I will soon switch cars, so, the goal was to keep the car modifications
    to the minimum. That’s why the monitor is not built into the dashboard.
    Some photos:
    After some measurement and a lot of head scratching, what was a plain
    50x50 piece of plexiglass begins to take shape.
    This place looks like it was design to hold a Carputer. :P
    To protect and avoid vibrations, I decided to make a holder in foam to
    receive the Carputer.
    I used some fabric for that OEM look
    This is where all that ugly cables are hidden
    The worst part is to install all the cables. I used a tube to pass the
    cables. Installed the USB hub in the fuse compartment where I will
    connect the GPS, Touchscreen and a small extension to the dash for other
    USB devices like pen drives, etc...
    Oct 2005
    Didn't find a power switch that I liked, so instead, I transformed the
    lighter to be used as a power switch. Installed a small switch in the
    back of the lighter and now I just have to press the lighter in to
    switch power on/off. There is also a small reset button as you can see
    in the photo.
    The GPS is hidden under need the front speaker cover. Works ok, but
    sometimes I must put it on top to get proper reception
    In the beginning I installed the monitor on top of the dash but then I
    moved it to the bottom and it works a lot better for me.
    You can see the USB connector next to the cell phone holder.
    I wait that they have liked
    Takes it in the Rear kevinlekiller's Avatar
    Dec 1969
    Where the penguins and polar bears live.
    The trunk is simply amazing!
    Constant Bitrate mccdeuce's Avatar
    Oct 2005
    Annapolis, MD
    i really like the cigarette lighter switch. just hope some unsuspecting fool doesnt get in and try to light a cigarette.
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    like the case mount in foam. neat idea
    Lez, more widely known as flez1966
    Aug 2003
    Orange County, NY
    Your install looks really nice! That is a nice spot to hide the GPS reciever.... my one suggestion is since the speaker grill is made of metal, maybe you can try making a set of covers out of some kind of plastic or non-metal composite to allow the signal to better pass though.
  1. VW Golf Mk 3 III
    By krog in forum Show off your project
    Last Post: 08-05-2006, 03:48 AM
  2. 1998 Vw Golf MKIV Carpc buildUp
    By LarsTDi in forum Worklogs
    Last Post: 03-07-2006, 05:51 AM
  3. Replies: 33
    Last Post: 09-01-2005, 04:14 PM
  4. Golf III audio system
    By erazor in forum Car Audio
    Last Post: 09-01-2004, 07:33 AM
  5. Golf III?
    By erazor in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-14-2004, 08:55 PM
