Results 11 to 20 of 22
Thread: 2002 Acura TLS laptop install
  1. #11
    Aug 2004
    Italy
    Nice work!!!
    Just one question:
    How do you wake your lap-top?
  2. #12
    Oct 2004
    NY
    really nice install.... any problems with usb & cable lengths.... how do you have the laptop secured... is it easy to remove? I love the way you adapted the cf skin to roadrunner... real slick
    nice job, good luck with it
  3. #13
    Jul 2005
    Colorado
    @proximo- Your skin works really well for me. I know how much work it is to put these together and you did a great job.
    @solokimm- The push button on the lower right part of the screen is wired to the on-off switch of the laptop so I manually jump start it out of standby every time I start the car.
    @turbocad6- I haven't noticed any problems with the long xenarc usb connection. Obviously I had to extend the usb and video cables and it seems to work well. The laptop case is resting on the floor of the trunk with some fairly hard closed cell foam to cut down on any vibration noise. I also have fixed bolts I mounted to some sheetmetal above the wheel well to hold the box tight to the side. It takes about 30 seconds to un-cable and un-bolt and remove from the car.
  4. #14
    Mar 2004
    Maryland/NOVA
    how did you wire the usb cam?
    nice install!
    2001 Acura CL traded for a 2006 Subaru Legacy GT
    7" Lilliput Touchscreen
    NANO-ITX+m1-atx
    512 DDRsodimm
    60g SATA Laptop HD
    4x Apple DVDslot
    digimoto OBDii
    mS GPS
    mini BT keyboard
    relocated HU faceplate
  5. #15
    Jul 2005
    Colorado
    Thanks!
    There is a grommet with some wires exiting the trunk that I managed to shove the USB connector through.
  6. #16
    Constant Bitrate thunderdepot's Avatar
    Sep 2005
    How do you get the laptop to turn on? And how are you powering it?
  7. #17
    Jul 2005
    Colorado
    Quote Originally Posted by thunderdepot
    I am using a standard dc-dc laptop converter like:
    http://www.powerstream.com/ADC.htm
    As I mentioned above, I have a momentary push button switch in the lower right corner of my screen mount that connects to the on-off switch of the laptop.
  8. #18
    Apr 2005
    Homer Glen, Il
    Quote Originally Posted by proximo
    Umm, I believe he tore up the dash himself :P
    Nice install, good to see someone using my skin!
    I was making a joke.
  9. #19
    May 2005
    great job! You just took the scarey out of this project. I am going to tackle my wife's Sienna first but then I'll do my (new) 02 TL-S. Awesome job on the laptop case.
    Thanks so much for the pics, man! That custom dash kit is simple but brilliant.
  10. #20
    Dec 2003
    Long Island
    Hi, installation looks real slick! Assuming you completely removed your stock HU, I'm assuming you're running audio to your amp and then out to all of your speakers/sub?? Also are you controlling volume exclusively through the software or do you have some sort of wired "gain" knob??
    '03 Acura TL PC FINISHED!!
    MP3CAR
  1. 95 Acura Integra install
    By Meltman in forum Show off your project
    Last Post: 02-27-2006, 12:00 PM
  2. Replies: 2
    Last Post: 07-01-2005, 05:20 PM
  3. 97 Acura Cl carputer install
    By elserpiente in forum Show off your project
    Last Post: 04-11-2005, 04:48 PM
  4. Anyone install LCD in Acura Vigor?
    By NorthGaVigor in forum Car Audio
    Last Post: 06-08-2004, 12:24 AM
  5. Replies: 11
    Last Post: 12-02-2003, 07:29 AM
