Results 1 to 10 of 20
Thread: 1999 Buick Century Custom 4-Door
    Oct 2005
    Fairfield, Iowa
    I finally finished my secret project! I mounted this in my car using a 7” Xenarc computer monitor w/touch screen in a special GM mount into the dash. It’s powered by a Travla C134 case using an M1-ATX power supply and a VIA SP13000 motherboard with 512MB of DDR400 very low profile memory. The optical drive is a slot loading DVD (dual layer) burner and the 80GB SATA 5400 rpm notebook hard drive. I’ve got USB BT 2.0 dongle in the back running Widcomm’s 4.1 stack (read high-quality audio profile) and D-link USB 802.11G w/turbo mode (I have a D-link router) and get 108Mbps in my garage.
    I removed the stock ashtray and it's a perfect fit (7" wide). I haven't tried to move it further back yet until I get all the wires tucked in and away.
    Now, I just need to clean and vacuum my car! Good thing the McDonald’s wrappers aren’t showing! J
    Diane~
    FLAC Spaghetti's Avatar
    Jul 2003
    Spagcave, in da UK Today's phrase: J'aime Alizee
    Wow, that looks great - love that bezel thing you got going there
    In da club....
    ALIZEE WANTS YOU.....
    (\__/)
    (")_(")
    Bunny's first poo
    __ U
    Takes it in the Rear kevinlekiller's Avatar
    Dec 1969
    Where the penguins and polar bears live.
    I was curious to see how it looked before , So I went on google and looked for a stock dash photo. That car is perfect for a toucscreen!
    Oct 2005
    Fairfield, Iowa
    Did you notice the ashtray below? I removed it and inserted the Travla C134 case in the same slot. It fits really nice and is really held in by the pressure on the sides.
    Variable Bitrate Fraychild's Avatar
    Jan 2005
    Somewhere I Belong ~
    Looks real nice - It came out perfectly -
    If I may suggest, I'm not sure of what's holding the case into place, but you might wanna make sure it's secure - maybe add some strong brackets?
    Also, your idea of pushing it further back into the dash shouldn't be taken lightly, so try to do what you can to make that happen so it sits a lil' more flush... The reason behind my suggestions? Security and Safety...
    Been a victim... Besides that - A++ setup!!
    VER. 3.0- Check out below:
    車コンピュータ 3.0
    Variable Bitrate BIzFlawless's Avatar
    Oct 2005
    Tejas
    Very nice setup! came out looking stock exept for the pc itself but still its very nice
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Wow!!! How does MCE run on the Via?
    @BIzFlawless: do you have the full version of your avatar?
    Peace,
    Rafster
    Oct 2005
    Tejas
    @Rafster: No
    Oct 2005
    Fairfield, Iowa
    Media Center 2005 runs quite well on the VIA SP13000. I also have 512mb of DDR400 memory, which I'm sure helps it out a lot!
    Quote Originally Posted by Rafster
    Peace,
    Rafster
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    Nice install, that 'double din' screen enclosure looks rather good.
  1. Replies: 35
    Last Post: 07-11-2006, 07:07 PM
  2. self destructing $900 door actuator/ toyota sienna
    By turbocad6 in forum Off Topic
    Last Post: 09-24-2005, 08:59 PM
  3. 1999 Buick Regal
    By Chairboy in forum Show off your project
    Last Post: 04-20-2005, 11:23 AM
