Results 11 to 20 of 23
Thread: 2000 Chevy Suburban install
  1. #11
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Damn! That is the blurriest screen i've seen!
  2. #12
    Constant Bitrate stuseed's Avatar
    Jul 2005
    Scotland
    Red Dwarf fan?
  3. #13
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Hey Pip...
    We just upgraded the 97 suburban to an '02 with second row captains chairs. Thinking of following your example on the location of the case
    Nice to see the pics. Should we plan a spring meet in '06?
    Cheers
    TruckinMP3
    Read the FAQ!
  4. #14
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    Quote Originally Posted by 0l33l
    Camera was out of focus
  5. #15
    pip
    pip is offline
    Mar 2004
    Parker, CO
    Quote Originally Posted by stuseed
    Red Dwarf fan?
    Absolutely, Red Dwarf rocks!
  6. #16
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by pip
    No duh. Maybe you should've used macro mode.
  7. #17
    pip
    pip is offline
    Mar 2004
    Parker, CO
    Quote Originally Posted by TruckinMP3
    Hey Pip...
    Cheers
    Its a great place to put it, plenty of room. Another meet would be cool
  8. #18
    pip
    pip is offline
    Mar 2004
    Parker, CO
    yeah, probably. I'll give it another try perhaps
  9. #19
    pip
    pip is offline
    Mar 2004
    Parker, CO
    (most) of the blurry pictures updated
    New picture of screen 'mount'...sits in center console cubby hole snugly & hole filled with a bar of dense foam:
  10. #20
    pip
    pip is offline
    Mar 2004
    Parker, CO
    Quote Originally Posted by Cris
    Sweet! Nice case too. What do those buttons next to the case do?
    One switch turns the main power to the opus on/off. The other controls accessory power input to the opus. This switch has three positions...
    1) Acc - accessory power....the PC will power on when I turn on the ignition.
    2) Off - no power at all....the PC will not power on.
    3) On - always on....the PC will power on immediately, even when the engine isn't running and will not stop when I turn off the engine either.
    This gives me full control, and several here have done the same. Its nice to know I can completely cut power so USB devices can't drain battery power.
  1. 2000 Silverado Install Completed...56k Warning
    By Jailer in forum Show off your project
    Last Post: 06-08-2007, 09:38 AM
  2. 2000 Denali Install - Lots of pics!
    By rulouder22 in forum Show off your project
    Last Post: 03-13-2007, 10:28 AM
  3. 2000 Monte Carlo SS install
    By snmnetwork in forum Show off your project
    Last Post: 04-06-2006, 12:05 AM
  4. Can I use nlite on an existing install?
    By omehegan in forum WinNT Based
    Last Post: 07-08-2005, 04:33 AM
  5. Where does ground loop isolator install?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 09-14-2000, 08:10 AM
