Here it is with the seat lifted. There is enough clearance for the lit fan to extract properly.
Also a picture of the screen mounted with the RAM mount and the trackball (touchscreen isn't as accurate as I'd like):
I moved my install to the truck from the Corvette. Thought I'd post some pictures, as the only people to see any of it are TruckinMP3 and dingofarmer in January. I wasn't finished installing at the time.
I ran 4 guage wire from the engine bay, under the truck and into the cabin under the rear drivers side door. I used a fairly hefty amp install kit from walmart. The PC sits underneath the second row passenger seat on the drivers side. Notice the switchbox I hacked together at the front to turn of power & control whether the PC come on with the ignition. The cables for screen etc run under the floormat and then underneath the center console. Hidden underneath the center console is a gyration keyboard wireless receiver, a USB 2.0 powered hub and a 3-way cigar-lighter adapter. The lilliput screen sits in a plinth that fits in the console cubby hole.
It looks quite good, though I may look into moving the heating controls to the center console and puting a non-motorized in-dash in their place. It performs really good and has no problems with video or iGuidance.
I'll happily answer questions anyone may have :-)
Here is the truck, and the pc under the 2nd row passenger seat:
A closer picture of the RAM mount and trackball. The cigar lighter with the light has a switch that controls power to the screen, the USB hub and my radar detector. I fabricaated a shelf that sits in my cupholder area to sit the trackball onto.
The wires going under the door will hook up to either my PSP or the Apacer USB-to-go hard disk I transfer files with:
Frodoplayer 1.10 with brightlife skin:
iGuidance embedded into FP. Loads at system startup & FP GPS button switches instantly:
FP playing video. Goodies hidden under center console:
XP desktop & GPS puck in place:
What case are you using for the carputer???
Nice setup!!!!
Sweet! Nice case too. What do those buttons next to the case do?
