Can you take pictures of the inside of your pc case. I have the same case with the Opus 120 and want to see how you wired everything, Thanks in advance.
yesOriginally Posted by tj!2k4
AZ! It is "cold" today tho - 55 deg right now
2005 Black Chevy Impala
As Peter Griffin would say, freakin sweet.![]()
that is a really nice install. great work!Originally Posted by rollholla
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
Added a rear-view wide angle CCD cam (yanlab ccd)
It is connected to the xenarc via V1 and when put in reverse it switches to V2 via a relay... so I can view it all the time, and it also automatically switches when I put the FX in reverse
looks really nice. That image of the camera looks really good. How is at nigth time? What camera is it? specs?
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Very nice install. I'm curious about the camera too, where'd you get it? And any night shots? Also, how did you wire it up to automatically switch inputs? Does it go back to VGA when you take it out of reverse?
I like your location of your GPS receiver. My hatch is similar because it has room where yours does where the top taillight is, i was just wondering if your GPS receives a good signal there? I thought it had to be in clear view of the sky. Temporarily i have mine on the dash and sometimes it doesn't even get a good signal![]()
what a sweet install. very impressive.
wow this def looks like a clean instal....great job!!!
Great job on the install...I wish I had your skills and balls. I have the same display in my car and in the end had to pay to get my system installed.
Check out my install pics; http://mp3car.com/vbulletin/showthread.php?t=70842
