got my new center shelf and my HDD mount under controll
the black things in the angle are rubber gromits and the head of the screw in the side of the HDD is a tight fit in the middle of the gromit..
im not familia with ProE
might check it out
update on the box..
im still just hacking little bits out of it to make the dash fit back on over it..
had to change the design a little.. wont be able to put the big fan in the middle because the ash try is there.. and i also had to make a new shelf inside for the HDD
more pics soon
Thats a sweet install, I can't wait when I start mine, but I still got ages 2 go!!!
Mirage 2003 model
if you do not have the truck any more ill buy the enclosure from you.
email me
i suggest you make the 90mm the intake and the 40mm the exhaust, then put a fan filter on the intake. this will create positive pressure in the case so it wont suck dust through the cracks. the way you have it now the thing is a vacuum and it will accumulate tons of dust inside very quickly. should also make for better overall cooling.
