i like it, especially the way the case blends in with the trunk.
is there any online store that sells the stuff you covered your case with??
thx
and also how does a 150w opus power all that stuff??
My car and system.
Saab 9-3 Viggen
Liliput touchscreen was tilt and slide now no more
Athlon 3000 xp
Radeon9600
512Mb Ram
80gig toshiba 2.5 " H/drive
MSI ATX M/board
Bluetooth
WiFi 802.11g
USB 2.0 4 port hub
XP Media centre 05
Opus 150w power
Webcam
Roadrunner
2 x Clarion Amps
ETC,
Liliput was tilt and slide until the mechanism decided to stop working. I removed the guts and screen, placed it over the double din dash. Circuit board is behind.
Will mount the screen into the dash in due course.
Saab 9-3 Viggen (270 BHP)
Liliput touchscreen
Athlon 3000 xp
Radeon9600
512Mb Ram
80gig toshiba H/drive
MSI ATX M/board
X-micro 802.11g
Bluetooth
USB 2.0 4 port hub
Media centre 05
Opus 150w power
Roadrunner
thx
love the car and the install, good job.
Originally Posted by romul
i cover the sub boxes i've built with carpet from www.partsexpress.com which looks similar to the carpet he used
nice install....but that smiley face keeps freaking me out!
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
The Opus power supply does indeed power the complete system excluding the cooling fans and monitor obviously. Really impressed with the power supply as it was second hand from good old eBay. (£50) Much better than the first option which was a couple of 12 volt security light batteries connected in parallel to the main car battery running a 12/230v inverter. Had all kinds of problems with interference, noise and high drain etc. This all fitted behind the box on the left side of the boot along with a 250 watt ATX power supply ( lot of humming and fans running ) still you live and learn.
I have tried to keep the car original without having to drill to many holes and cut away anything so to mount the boxes on the left and right i had to make a second floor and accommodate the wiring, spare wheel and second amp hence why the boxes match the floor. Will in due course match in the sides as well.
I bought the acoustic carpet from a store near me rather than online as i have found that the quality, thickness and durability can vary greatly from manufacture to manufacture and you can't beat checking out the stuff in person before you buy. I will say though that in my experience cheap is not always best when using this stuff.
By the way the smiley you will be glad to know has gone!
Liliput touchscreen
Athlon 3000 xp
Radeon9600
512Mb Ram
MSI ATX M/board
X-micro 802.11g
Bluetooth
USB 2.0 4 port hub
Media centre 05
Opus 150w power
Roadrunner
I have a question... I have been seriously considering something like the Viggen or Base coupe. The thing above the radio, what does it do? Is it just a driver information system? If so, can I just have the PC give me that information and put a regular CD Receiver there (with minimal modification?
Peace,
Rafster
Had got the same problem.Originally Posted by chisel900
It is dur to bad information in an EEprom : the 24C02 one
i have the originl code for it.
I have repaired mine with it.
tell me if you are interrested in knowing how to repair.
