Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: Washing Machine - A rolling terrabyte
  1. #21
    Jan 2002
    Now is it 1TB of disk on RAID 1 giving you 500GB of useable space, or 2TB of disk on RAID 1 giving you 1TB of useable space? Or is it multiple drives drives in RAID 0? Or are you doing something crazy like RAID 0+1?
  2. #22
    Feb 2006
    Multiple drives on Sata Raid 0
  3. #23
    Newbie silverbackman's Avatar
    Aug 2005
    Calgary, AB
    I will def. post some pics, but still in the planning stages. I have all the parts and the addtional dash pieces (love the junk yards) and I've CAD the center console/dash. I've just got to put it into reality. I've been having trouble with the HU placement, and have been considering removing, but I like the way you side mounted your face on the center console. I might give that a try.
    There is no such thing as gravity, the world just sucks!!!
  4. #24
    Feb 2006
    Yeah...we spent many a dusty day in the junkyard...
    We have absolutely NO head unit...just an alpine controller that is velcroed to the side of the center console so we can remove it and anyone in the car can use it.
    David
  5. #25
    Aug 2005
    Calgary, AB
    Here's what I've come up with so far.
    What are you using for fm reception, without a HU?
    What are you using for you wardriving?
  6. #26
    Feb 2006
    http://sewelldirect.com/tvtunervideo...fmradiopci.asp
    Does both TV and Radio, plus depeding on which software you use, you can get TIVO functions as well....
    The reason I don't have a head unit is I don't need one...we went for complete replacement with a high-quality EQ unit. Also, I wanted DTS and Dolby Digital/AC3 surround sound, so the Alpine unit has the built in decode functions. I go optical from the sound card direct into the alpine "black box" in the canoe. The controller is basically for volume control (I leave the PC output cranked as it is the limiting factor - dynamic range-wise).
    Additionally, for wardriving, I use a custom made omni antenna with a Linksys card and use NetStumbler with my GPS to locate AP's. I usually keep it off because its so powerful, it puts transients into my music/movie sound, so I just enable it when I want to.
    Great design. What about cooling? Where are your fan(s) going to be?
    David
  7. #27
    Aug 2005
    Calgary, AB
    Haven't worked the fans in yet. I want to build the console first (or at least a mock-up) to determine best airflow, but based on the design, I should (I hope) have a mulitiude of fan push/pull locations. I'm actually thinking of using a vent system that would allow me to draw off the heat into the cab in the winter, and vent it out of the cab in the summer. Just one of those 'I wonder' ideas.
    How's the FM reception on that card?
  8. #28
    Newbie 91silvy's Avatar
    Jul 2005
    Arr-can-saw
    silverbackman, I also have a 91 silverado and your project looks quite ambitious. Do you just plan on extending the raised area of the dash over about 15 inches, because it looks like you're putting the monitor in the middle of the dash? If so, what would you put in the area where the HVAC and OEM radio were?
    J-Bock
  9. #29
    Aug 2005
    Calgary, AB
    Hey J-Bock
    I don't want to hi-jack Davids thread here, so I'll PM you. Dave's rig is too awesome to take away from it. Thanks again for the insperation Dave. Anyone else who has questions for me, just email or pm me.
    Jeff.
  10. #30
    Constant Bitrate ChaCha's Avatar
    Nov 2004
    Los Angeles
    That is just AWESOME...truly. How do you like the TV/FM card?
  1. Washing machine motor
    By Fox_Mulder in forum Off Topic
    Last Post: 06-03-2005, 03:44 AM
  2. Media Files Synchronization
    By IntellaWorks in forum Software & Software Development
    Last Post: 01-20-2005, 08:37 AM
