good install!
Just put together a system in a Miata. Tight squeeze but I was able to pull it off.
Small amp and small computer helped keep the project easy to work with.
More pictures and info at http://www.angibabi.com/miata/index.html
good install!
Thank you. It was just something that needed to be done. Just a matter of time. I think all cars should come with some type of computer system!Originally Posted by skadoo323
I like it. All those wires came from the sterio and aircon etc? Did you have a system to keep track of it all when you unpluged?
Continued Worklog... Upgrades in progress:
*15.4" WXGA LED backlight touchscreen upgrade
*Custom fiberglass dash bezel
Looking good!![]()
Hi. Thanks for looking.Originally Posted by BiGGy
Yes, actually the first picture you see is the wire harness that was used for the aftermarket stereo. It looks like a big mess but if you ever took a look at one of those aftermarket plugs, there is a lot of wires to them. The crimp style connectors that they used makes it look messy.
No AC was installed in this miata (which was a good thing in this case). That was one reason I was able to put the unit in the dash area. The spec class or R miatas have no A/C or Power Steering. They are turly a mans driving machine to be driven on an open track (or in my case, around town while having fun with the computer).....//
