Originally Posted by I302K
its one if the best, check it out here:
Release - MC2.0 Skin
the trunk isn't much to look at, but i'll be building a pseudo sub enclose to hide the PC and provide ventilation (via speaker grill).Originally Posted by rando
I think you shoulda ran the wires under the false floor or perhaps under the right sidewall carpeting. Cause that wireing looks like it was done by a two years old boy...
Shotgun! - An Advanced CarPC Software Solution!
Originally Posted by ITL
its not a perfect match, but honestly, no one can tell unless i point it out to them. and when i do, they think i'm crazy obsessive. i used dupli trim paint from advance auto parts, flat black. they also sell textured varieties, but for my purposes the flat black worked perfectly.
i need to get some rubber-like material for the lower compartment, i have a slight gap between the plexi and the shifter housing. did you seal if off, or did you manage to get a perfect fit?
Originally Posted by Saturated_Fat
you still here?! shouldn't you be buying some megans? its not going to save you from the TL, son. get used to my tail lights!!!
0l33l
I got a perfect fit. I notched the top corners in the Acura trim piece. This allows the plexi to slide down into a groove. For the bottom, I just beveled an edge that fit perfectly up against the front of the trim piece around the shifter. The plexi doesn't move and there are no gaps! Once in place, it never needs to come out, so I secured it with some super glue just in case.Originally Posted by theklassic
CarPC #3: 99% Complete
Pentium M 1.7Ghz, 1GB DDR2 RAM
DVD/CD-RW installed in dash below monitor
OEM LCD relocated for 7" Touchscreen
Wi-Fi, GPS, PS2 controllers...
500+ full albums
4,000+ video games
music videos, movies, & more!
old carPC
Great install, looks very well done. I have a question aside from the carputer; are you a photographer? The pictures are very well taken/done.
___________________________________
1996 Accord Ex Carputer
Soon to come 2008 WRX 5-door Mac-carputer.
thanks rida, i do art and photography on the side for fun.Originally Posted by AznRida
very nice install. i think acura should have put those displays down at the bottom to begin with.
great job!![]()
My brother is in school for photography so I know good pictures when I see them heh.Originally Posted by theklassic
