Did you have fiberglass in the fornt over the buttons etc... to?
How do i make the fiberglas to the dash? whit some kind of glue????
The red thing,,, is kust fibreglass, I think its called isopon p-40 fibreglass filler.Originally Posted by stClem
I roughly mounn=ted the screen where i wanted it to go with some masking tape, then from the rear, i filled it up with some fibreglass, and let it set, when i pulled the masking tape off, thats what you left with.
To get the facia off, you have to pull the radio out first using a set of "pins" or a couple of thin nails or whatever you can use, there are 4 screws behind it which hold the facia in place, take these out, then im pretty sure the only thing holding the facia in place are 3 clips which just pop out if you lever the face off.
if you need any more help, give me a shout..
Celeron 2ghz, 1 gig ram, 200 gig sata, DRU-R100 radio, wifi g, 7"lilliput touchscreen, opus 150w dc-dc, laptop slot load Dvd, BU-353 GPS , Destinator, Road Runner MC2.0
http://www.mp3car.com/vbulletin/show...ord+focus+2000
Or is fiberglass filler some kind of stoffer, some like this?
And please tell me what dvd player you have...
the fibreglass, is a mixture of firbreglass particles and resin, you add hardener to it, it comes out like a sticky goo,,,, then you mould it to the shape you want, then it sets hard like plastic..
I sugest you visit this section,
http://www.mp3car.com/vbulletin/fabrication/
the dvd i am using is a slot loading laptop dvd combo, i think its a panasonic CW-8121-B I bought it off ebay, but it seems to work fine.
yep like that!Originally Posted by stClem
Since your DVD drive is not USB, what kind of cable do you run back to your Motherboard? Isnt that too long of a stretch for IDE?
what is done between this two images?
In order to connect the laptop dvd rom to the computer in the boot (or the "trunk" for you yanks...lolOriginally Posted by drewbad
) I had to use a convertor to convert the laptop drive to ide, then another convertor ide to usb, then i just ran a long usb lead into the "trunk"
ebay to the rescue again!
ahhhh,,, well in the 2nd picture i had covered the fibreglass with some body filler (cataloy) ispon p38 then sanded it down smooth to the shape i wanted!Originally Posted by stClem
