Page 12 of 14 FirstFirst ... 234567891011121314 LastLast
Results 111 to 120 of 131
Thread: 2003 Honda Civic.
  1. #111
    May 2006
    Calgary, Alberta
    Quote Originally Posted by nameeri View Post
    The best touchscreen monitor right now is the MP3car.com's transflective one. It has the best daylight visibility. The price has come down since its introduction so i would go for that. As far as power, you should get an opus for your needs its probably the best bet.
    That's a Lilliput though. When is the Xenarc being released?
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  2. #112
    Newbie djhonda04's Avatar
    Nov 2006
    Florida
    hey guys honda civic lx 04 got problem cannot remove panel to install monitor
    how do u remove her
  3. #113
    Mar 2006
    Colorado, but Canadian!
    01-04 are pretty much the same.
    Pry off the panel where the cig lighter is and that weird useless slot.
    THen there are some screws right above it inside that you must unscrew.
    THen just pry the bezel off. There are lots of little plastic tabs so be careful. I did it with a butter knife and slid it along the seam until it hit something (a little tab) and then twisted the knife a bit to pop the tab out. Pretty easy once you figure it out!
    1.9in x 2.9in -- 47mm x 73mm
  4. #114
    Nov 2006
    Florida
    I Hate Honda
    Man i cannot belive how much time this panel take. i riped off all thing before i figure out that i could be under radio.
    Now it to late but thanks any way.
    I need another help so far. i got two 220W amplifires and one 12" Sub . How can i connect two amps on one speaker. They a brigde amps.
    Trying to figure out but is not working my way.
    Thanks if anyone know Help needed.
    MY pc just burn out.
    im going to get new one. Sonest im good with money.
  5. #115
    Mar 2007
    Phoenix, AZ
    This is a nice build. Going to get started on this project for my 01 civic. Any tips on the wiring of everything? TIA
  6. #116
    Mar 2006
    Quote Originally Posted by latinem2 View Post
    civics are easy to wire. I have an '01, and it was simple simple.
  7. #117
    Mar 2007
    Phoenix, AZ
    Quote Originally Posted by 2k1Toaster View Post
    any helpful links on the wiring? All i've seen is the end results. But not much of the wiring. That the part that im having the most trouble on figuring out.
  8. #118
    Mar 2006
    What kind of wiring do you need? Do you need the under dash wiring guides like which is accessory, which is door lock, that sort of thing?
  9. #119
    Variable Bitrate nameeri's Avatar
    Mar 2006
    SoCal
    Wiring is very easy, you will have to remove the entire center console, the back seats, the rear deck (if you are upgrading the rear speakers), pull up the carpet on one side, take out the front passengers seat to give you more room to work with. Also , remove the cigarette lighter plastic piece on the dash and then remove the entire piece that contains the vent heating/AC controls. Basically you gut the inside of the car, run your wires and then put it all back together again. that makes it a stealth install.
    Civiputer: Dont have one anymore, but here is what is used to be!
  10. #120
    Mar 2007
    Phoenix, AZ
    Well, what i need help with is the acutall wires that are needed. What brand of the wires the best to use. Like what wires conect to the screen, from the motherboard, to the hardrive. etc. you get me? =) I've take apart the center console and dash so im familiar with that.
  1. 2003 2004 2005 Honda Accord CarPC
    By Adam2312 in forum Newbie
    Last Post: 02-09-2009, 09:25 PM
  2. honda civic 2005
    By jbelle7435 in forum Newbie
    Last Post: 11-25-2006, 06:27 PM
  3. A Total NewBie - Install on Honda Civic Hybrid
    By suhaildesigns in forum Newbie
    Last Post: 01-16-2006, 08:16 AM
  4. WTB: complete kit for honda civic 2003
    By thomasamiller in forum Classified Archive
    Last Post: 11-21-2005, 01:17 PM
  5. 1997 Honda Civic CD Changer Help!
    By gooch in forum General Hardware Discussion
    Last Post: 09-18-2005, 10:01 PM
