Page 13 of 14 FirstFirst ... 34567891011121314 LastLast
Results 121 to 130 of 131
Thread: 2003 Honda Civic.
  1. #121
    Mar 2007
    Wiring and such.
    I was wondering that myself but I didn't want to ask until I actually attempted the install. I noticed someone had their head unit installed underneath their xenarc and never mentioned how they wired everything up...
    I am assuming it is common knowledge that you use long VGA cords for video, long USB cords and extensions to reach front to back. say 10ft or so.
  2. #122
    Variable Bitrate nameeri's Avatar
    Mar 2006
    SoCal
    Assuming that your computer (the actual box that contains the hd, cpu, memory, etc) is all in one case then you will need the following:
    USB extension cables for your USB peripherals,
    VGA extension cable for the screen
    14 ga. wires (red, yellow, black) for power connections to the PC
    You will also need to fabricate some power wires for the monitor if you plan to run that from the PC power supply.
    Audio cables with mini-jack to RCA type connectors
    Heavier ga. power wires if you want to install an amp, etc....
    Civiputer: Dont have one anymore, but here is what is used to be!
  3. #123
    Mar 2007
    Question Power supply question.
    Nameeri: One more question, if I do decide to run power wires from the pc power supply (M2-ATX) will the wires just be sticking out of the back of the pc or is there some sort of port attached to the back, connected to the pc. In other words when you look at the back will there be wires sticking out (red & black) through a hole in the pc? The VGA will obviously be connected to a VGA port on the back, usb to usb port and ps2 to ps2 port but what about power??? Again, once I begin the install I'm sure things will look much clearer but in planning this all out I want to have every detail understood. thanks alot.
  4. #124
    Mar 2006
    SoCal
    You will need to make those connections easily detachable. So yeah, you will have wires coming out the back of the pc case. If you use Molex connectors, you can make the connections nice and clean. Here is a pic of what I mean. This is the way that I did it on my carputer.
    you can get molex connectors from Frys, or any other electronics parts shop. They are fairly cheap.
  5. #125
    Mar 2007
    Here is how I molded mine..
  6. #126
    Mar 2006
    Colorado, but Canadian!
    What molded? It's a flip out isn't it?!
    1.9in x 2.9in -- 47mm x 73mm
  7. #127
    Mar 2007
    Look up a stock 01-05 bezel on ebay. The dash is molded around the deck (which is a pop out). The dash is also molded around the DSP below it (which is alo painted the same color.)
  8. #128
    Mar 2006
    SoCal
    You can sort of see it here, but another pic taken with more light at a better angle probably would have helped. I see what you are saying by 'molded' though. It looks nice, but that glossy black completely undoes the stock look and feel
  9. #129
    May 2007
    Well this is my first post on here. I currently have an 05 civic and looking to put a pc in my car. Ive learned alot from this thread itself. My question, and its probably a stupid one, to run GPS, all you need is the software and the antenna? As well as the satellite radio? Or is there more to it?
    Im going to order my screen and bezel probably this week and go from there. Im from socal and I may need some help if someone is willing to answer my stupid questions. haha.
    The setups you guys are running are looking cleean!!!
  10. #130
    May 2007
    btw nameeri...that screen looks badass..i may need some help if youre willing to help a n00b. haha. Ive done hundreds of custom stereo installs, so the wiring and all that good stuff is easy, its just the hardware/software that ill need help with. lol
  1. 2003 2004 2005 Honda Accord CarPC
    By Adam2312 in forum Newbie
    Last Post: 02-09-2009, 10:25 PM
  2. honda civic 2005
    By jbelle7435 in forum Newbie
    Last Post: 11-25-2006, 07:27 PM
  3. A Total NewBie - Install on Honda Civic Hybrid
    By suhaildesigns in forum Newbie
    Last Post: 01-16-2006, 09:16 AM
  4. WTB: complete kit for honda civic 2003
    By thomasamiller in forum Classified Archive
    Last Post: 11-21-2005, 02:17 PM
  5. 1997 Honda Civic CD Changer Help!
    By gooch in forum General Hardware Discussion
    Last Post: 09-18-2005, 11:01 PM
