Page 9 of 14 FirstFirst 1234567891011121314 LastLast
Results 81 to 90 of 131
Thread: 2003 Honda Civic.
  1. #81
    Variable Bitrate nameeri's Avatar
    Mar 2006
    SoCal
    Here is the bezel trim piece, you will have to cut the tabs off completely
    Civiputer: Dont have one anymore, but here is what is used to be!
  2. #82
    Mar 2006
    SoCal
    And here is what it looks like once you are done.
  3. #83
    May 2006
    Calgary, Alberta
    Nice, so I understand how much of the sides has to come off - a lot. Basically so there's no 90 degree turn down the side, just the frame on the front. But what about the top and bottom? The top is real thin as it is and the bottom has those buttons. How can you shave it down there?
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  4. #84
    Mar 2006
    Colorado, but Canadian!
    You remove the buttons!
    You can relocate them or put the ir receiver in the vents or somewhere so the remote still works to simulate the buttons.
    1.9in x 2.9in -- 47mm x 73mm
  5. #85
    Mar 2006
    SoCal
    Exactly, dont worry about the buttons. I have my IR reciever mounted in the left vent and I just point the remote so you dont need the buttons, they serve no purpose at all if you have the remote.
    To get an idea of how much to remove from the top and bottom, just do test fits as you chop the plastic off, or just take some measurements of the opening and cut the bezel accordingly, thats what I did.
  6. #86
    May 2006
    Calgary, Alberta
    It's another 11.5 hours at work tomorrow, so I'll work on it during the day and post up what I have left of it tomorrow night!
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  7. #87
    Constant Bitrate Eternalodyssey's Avatar
    Oct 2005
    St. Louis, MO
    I would defenitely go with 2k1toaster said and remove the buttons, the remote works just as well. Just don't lose the remote!
    Check out the updates. Project 2003 Dakota worklog: http://www.mp3car.com/vbulletin/worklogs/85490-project-2003-dodge-dakota.html
    IS JACK BAUER GONNA HAVE TO SMACK A *****?
  8. #88
    May 2006
    Calgary, Alberta
    How did you extend the wire to the IR receiver?
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  9. #89
    Mar 2006
    SoCal
    its pretty long already, shouldnt need to extend it at all. The IR wire in my xenarc was about 9 inches, plenty long enough to run up to the air vent. Make sure that you make a deep cut out on the bottom of the vent so that when you put the entire piece back into the car, it will clear the vent outlets.
  10. #90
    May 2006
    Calgary, Alberta
    Quote Originally Posted by nameeri
    9 inches? My IR is about 5 miilimeters from the bottom of the screen, is there some slack behind the screen I didn't see or something? I have the TSV. Maybe you can pull it out, I might have just not noticed.
    I got all the curled edges cut off the screen bezel, think it needs to come in even more than that? There's a Xenarc stamp on the bottom of the bezel, did you cut below or above that?
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  1. 2003 2004 2005 Honda Accord CarPC
    By Adam2312 in forum Newbie
    Last Post: 02-09-2009, 10:25 PM
  2. honda civic 2005
    By jbelle7435 in forum Newbie
    Last Post: 11-25-2006, 07:27 PM
  3. A Total NewBie - Install on Honda Civic Hybrid
    By suhaildesigns in forum Newbie
    Last Post: 01-16-2006, 09:16 AM
  4. WTB: complete kit for honda civic 2003
    By thomasamiller in forum Classified Archive
    Last Post: 11-21-2005, 02:17 PM
  5. 1997 Honda Civic CD Changer Help!
    By gooch in forum General Hardware Discussion
    Last Post: 09-18-2005, 11:01 PM
