I Am interested to find out what front end/skin that is, too.
Printable View
he's using Road Runner i think :)
stage3legacy... are you a member at legacygt.com? If not, come over and register :D
Ditto that, because it looks sweet, but with my past experience, if that's just hot glue or anything remotely similar, when it heats up (either from exterior/interior temp or from the monitor itself) the glue loosens up and doesn't hold. For what it's worth... ;-) But that's great if you'd had no problems. It does look sweet :rock:Quote:
Originally Posted by Fraychild
Cool bring that Suby love!
Member of LGT here, been wanting to do a carputer since my last car, a Nissan Maxima.
Glad to see another wagon with a carputer install. I think I want to try to utilize the little shelf in the glove box rather than the nifty bin under the floor - I love that thing!
Keep it up, see you on legacygt.com!
I am sorry to admit, hot glue sucks.
It was ok for first two to three months, then weather turned hot, next thing I noticed was that screen was shaking...
I used 5 mins epoxy to re-glue everything back, it does the job much better.
http://mysite.verizon.net/legacygt/image/DSC03265ss.JPG
http://mysite.verizon.net/legacygt/i...SC03270sss.JPG
http://mysite.verizon.net/legacygt/i...SC03298sss.JPG
http://mysite.verizon.net/legacygt/i...SC03309sss.JPG
http://mysite.verizon.net/legacygt/image/aaaiuoj.jpg
DONE!
i saw your post in mobile 01. Very nice install... the last pic looks like factory system.
Great :)
Let me know if you ever find anythng that matches the factory bezel texture. I finished mine with some rubberized bumper spray paint and sanded and painted to match the dash so the match is pretty close, but I would prefer the rubberized smooth feel of the factory bezel.
As for my setup in the Outback, it is a laptop that clips down onto a docking station run from an inverter off of the lighter plug in the trunk. I ran the wires under the rear seat (but not the carpet as I couldn't figure out how to get it up) behind the stereo ot the screen. I also installed a remote power button soldered into the docking station to turn on the laptop (and turn off when it crashes :P)
My only two complaints about the wiring in my system is that I didn't order the clock relocation kit soon enough and get darkfox1's extra wires for it, so I cut and spliced the factory harness. Then I broke down and got the relocation kit so the clock would sit nicely where the ashtray is. That and I would like a better wiring setup for the VGA/USB/Power.
I was thinking of getting a project board and soldering the connections onto it and building a custom wiring harness for all 3 lines so it would be a quick disconnect for when I need to pull it out, etc... but I haven't gotten around to it/not sure the best way to approach it. I really don't like the idea of having the VGA calbe connected halfway down behind the radio and the USB extention cord/USB hub setup for the GPS and touchscreen the way it is now. I'll post pics one of these days...
Nice install!
But... Did you use your CarPC with the sunshine? Your monitor does not have any sun-protection cover above...
I ask it because when I use my CarPC, Sometimes I regret that have not made my cover more longer that it is.
