Page 4 of 11 FirstFirst 1234567891011 LastLast
Results 31 to 40 of 104
Thread: 2005 G35 Coupe Pentium M CarPC
  1. #31
    May 2006
    Calgary, Alberta
    With that trunk setup, is the plexiglass flush with the wood, or is it a little lower? I'm basically wondering how you mounted the plexiglass in the surrounding wood piece, I was thinking about making one as well.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  2. #32
    Maximum Bitrate Caelric's Avatar
    Sep 2005
    Bellevue, NE
    It is not quite. I mounted it underneath, with a sheet of plexi larger than the hole, and then mounted a sheet on top of that, exactly the size of the hole, to make it closer to flush. It is not quite flush, but it is close. To make it flush, you wuld have to have the hole, and then a routed out slot all around the hole, to fit the plexi in, and I am not that talented with the router.
    As for the bootskin, I have to find it, but here is the wallpaper I use. It is a jpg, but I can send you the original bitmap, or the psp files, if you want. When I find the bootskin on my computer, I will post that as well. The wallpaper is 800x480, by the way. I can also send you the Frodoplayer skins I made, which are modified FriBruMet skins. PM me with an email address that can accept 3+ mB files.
    Dave
    2005 Infiniti G35 6MT Coupe Black/Black
    Core Duo CarPC
    CarDomain page
  3. #33
    Variable Bitrate f1vlad's Avatar
    Feb 2006
    Nashua,NH
    Wow awesome enclosure for PC! I love it, good job!
  4. #34
    Sep 2005
    Bellevue, NE
    Ok, here is the bootskin I use. You have to use it with the freeware Bootskin program, located here
    If you have any problems, let me know.
    Dave
    Attached Files Attached Files
    Core Duo CarPC
    CarDomain page
  5. #35
    Sep 2005
    Bellevue, NE
    Quote Originally Posted by f1vlad
    The enclosure was made out of plexiglass, and then I encased it in the steel mesh, in an attempt to make somewhat of a faraday cage, to cut out RF interference to my radio system. I succeeded somewhat, but it still has some RF leakage. Oh well. It's always a work in progress.
    Dave
    Core Duo CarPC
    CarDomain page
  6. #36
    Sep 2005
    Bellevue, NE
    Did those skins and/or bootscreens work out for anyone?
    Dave
    Core Duo CarPC
    CarDomain page
  7. #37
    Sep 2005
    Germany
    that car is kewl...never seen it here..
  8. #38
    Sep 2003
    St. Louis
    Quote Originally Posted by Caelric
    Dave
    Yes, Thanks loads dude. Im using them on my 2003 G35 coupe. I think the brushed metal skin is more visable than the skin I was peviously using,(brightlife)
    Thanks Again
  9. #39
    _
    Mar 2004
    Little Elm, Texas
    looks good, just one question, and I've seen it many times before, but what is the purpose of a mini model of your car IN your car?
    I see it at all of the car shows, and I have yet to see the purpose behind it...lol
    Jan Bennett
  10. #40
    Sep 2005
    Bellevue, NE
    Bling.
    Other than that, it does cover up the top of the bolt that holds the entire amp/beauty board to the car. Really, though, no purpose other than bling, which is pretty much the same purpose as the capacitor.
    Dave
    Core Duo CarPC
    CarDomain page
  1. 2003 2004 2005 Honda Accord CarPC
    By Adam2312 in forum Newbie
    Last Post: 02-09-2009, 10:25 PM
  2. 2005 Infiniti G35 Pentium M CarPC
    By Caelric in forum Worklogs
    Last Post: 11-24-2006, 01:16 PM
  3. 2005 G35 Coupe Aftermarket Nav System
    By CAFHU in forum General MP3Car Discussion
    Last Post: 09-13-2005, 02:02 AM
  4. Where to DL old version of RR?
    By accentsound in forum Road Runner
    Last Post: 07-12-2005, 01:51 AM
  5. The computer is in! G35 Coupe
    By g35c in forum Show off your project
    Last Post: 01-12-2004, 04:41 PM
