hang on...deja vu!
i like your dash colour and those strut braces seem a bit silly!![]()
Almost happy with the install now
So thought its about time to put a few pictures up
Was getting really dishartend about ever finnishing relocating the climate controls. But once as i managed to get the bottom part of the dash of it was fairly easy
The boot
The PC
The Dash
Goind to re-carpet the PC and amp this weekend with a better match carpet to the OEM stuff
Might drop a Slot load CD underneath the PC
Bluetooth & WiFi still to install
Better fitting of the GPS receiver
Cant make my mind up if it would look better with a much brighter shade of silver for the dash
Id love some suggestions on improvments
not sure what else to do
What do you lot rekon then ?
and i know my steering wheel is on the wrong side![]()
got plenty of work in progress pics if you want aswell
hang on...deja vu!
i know bit of an attention hore me![]()
Very clean install!! Congratulation![]()
The old setup http://flickr.com/photos/ilyassx
The new setup http://my.opera.com/ilyassx/albums/show.dml?id=110701
Jetway J7F2WE VIA C7 1.5 GHz
512 DDRII 533
3.5" SATA2 H.D.D 200GB
M1-ATX
ELM327MS OBDII
Creative Audigy 4
PROGRESS:[########-]90%
well you deserve it. awesome job.Originally Posted by Maverick
i love you english people.Originally Posted by Maverick
nice install
[::::::::::] 100% - Planning
[::::::::::] 80% - Computer
[::::::::::] 0% - Fabbing
CarPC:
SP13000 / 120GB SATA 2.5" / 512MB DDR
8" Innovatek TS / Globalsat BU-353 / Engenius EUB-362 EXT
Slot load DVDRW / PS3 Wireless Keyboard
wat did u make the enclosure for the pc out of ? like behind the carpet got ne pics of installatioN?
Got a few pictures of the instalation
The dash front removed cut down to fit the dash bezel
had to cut the lower hole to size to fit the front of the stereo
the climate was here but will be being moved to the ash tray
Test fitted
fibreglass, fillered, painted ect you know the routine
Painted and laquerd
I had to carefully cut all the buttons above the screen about 4mm to fit in the smaller gap after the screen was in
Most of the PC built using a morex case
i removed the front panel and cut a hole in the lid lit and perspexed with a blue tinted perspex i had from an old computer case i had modified
Cut an MDF pannel to fit on the side of the boot.......... sorry trunk
Then trimmed it and fitted all the computer bits
the box to the left of the PC has usb ports on it with two 2 throw relays to cut the usb power when the PC is off
This bit took ages to build
small kids have there uses passing the cable sleeving around the cable while i fit it
wiring loom remote from the ignition to the opus, 12v & 5v from a morex to power the screen
got a few pictures of moving the climate but there a bit boring
that was a real pain to do aswell
and finally a few pictures of what is all been fitted to
I like that paint finish you did with that. I was going to put mine in the back quarter panel like you have done, but I don't trust drivers around here all that much seeings as how the car I've had has been rear ended 3 times.
Did you order that paint or what?
___________________________________
1996 Accord Ex Carputer
Soon to come 2008 WRX 5-door Mac-carputer.
