Page 2 of 18 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 172
Thread: 2004 Subaru Impreza WRX CarPC Install
  1. #11
    Variable Bitrate Redian's Avatar
    Apr 2006
    Connecticut, USA
    heres the IR reciever, i used my phone for the picture so bad quality, ill try and get my actual camera working again tomorrow too late for that now
    sidewalk, are you going to the hartford public meet?
    2004 Impreza WRX CarPC Install
    I am willing to host any legal downloads that may benefit the CarPC community - PM for info
    "When you go 0-60 in 4.5 seconds, you don't need a made up character called fast. Thats what makes a Subaru, a Subaru."
    DG4L
  2. #12
    Apr 2006
    Connecticut, USA
    i think i may have solved the frodoplayer problem... it has nothing todo with FP at all either, my touchscreen drivers just boot up w/ right click rather than left click, and thus... makes nothing happen
    now i must wait until the 16th before installing, thats when the acrylic comes and the amplifer. after i get that, ill setup the case for my computer, then install.
    DG4L
  3. #13
    Maximum Bitrate Sidewalksalvage's Avatar
    Mar 2006
    NJ/RI
    Good to hear you got the FP working. I think the IR parts are similar, but not exactly the same. If you can get a better picture it may help.
    Brown 2010
  4. #14
    Apr 2006
    Connecticut, USA
    camera is working... heres the pcture
    DG4L
  5. #15
    Mar 2006
    NJ/RI
    Alright well mine looks a bit different. Actually very different, but contains the same parts and the IR seems to be the same. Ive attached pictures, let me know if you want it or not.
    Brown 2010
  6. #16
    Apr 2006
    Connecticut, USA
    is there any markings on the phototransister?
    maybe it is the same one
    DG4L
  7. #17
    Mar 2006
    NJ/RI
    The only thing one the photo transistor is "V1" and is soldered to the "RE1" point on the board. However these are both generic information that wont help much. I did a little research online, It seems to me that most are very similar. If you want for $5 bucks shipped ill give you this and you can try soldering a three wire lead to it and trying it. Let me know
    Brown 2010
  8. #18
    Apr 2006
    Connecticut, USA
    Alright, next update... and a couple problems... i title it "The Good, The Bad, and The Ugly" (original dont you think?)
    first, the good stuff.
    I ripped out the radio and stuff top half of my console... here some pictures
    the pieces:
    my radio as of now, looks nice... dont you think? everything came out easily no hassles or anything there besides dropping a screw into the dash and having to get it out by blindly swinging my hand in the dash ^^
    Second, the frame.... this is where it gets bad...
    i did not damage the frame... but, the bezel does not fit in the frame... the left and right sides fit perfectly... but the bezel is too tall to fit perfectly in
    is it suppose to eb like this, and if i sand the down... will it fit like it should?
    and one other thing - how did everyone else with an 04 rex put it in perfectly? i.e. is mine bent or something?? it looks fine... so what did you guys do?
    so yeah, expect alot of work being done now that everything came... i should be done making the case for the PC by tomorrow
    DG4L
  9. #19
    Mar 2006
    NJ/RI
    Well looks good thus far. Probably sanding will help the screen, I dont know how others with a subaru do it but I assume it has something to do with the screen's bezel modification
    Lastly: The ugly.... i have been suspended from school for 5 days for "hacking" i.e. playing a video game on the computer... so yeah, expect alot of work being done now that everything came... i should be done making the case for the PC by tomorrow
    LMFAO. Well at least suspended for a good reason and now you have time off to work on the PC
    Brown 2010
  10. #20
    Mar 2006
    NJ/RI
    Oh, BTW did u want the reciever i have?
    And maybe, and i dont know if you want to do this, but sanding/cutting the console of the subaru is in order for the screen to fit. Because the screen bezel is metal it may cause problems.
    But then again, i dont know how much damage you want to do to the subaru
    Brown 2010
  1. 2004 Subaru Impreza WRX CarPC Install
    By Redian in forum Worklogs
    Last Post: 05-11-2006, 06:48 PM
  2. 2004 Subaru Wrx
    By Zip in forum Show off your project
    Last Post: 12-01-2005, 02:32 AM
  3. Does anyone have a Subaru Impreza auto pc under front seat?
    By Arathranar in forum General Hardware Discussion
    Last Post: 10-04-2004, 01:38 PM
  4. OBD connector on 2004 Subaru STi.
    By LESLIEx317537 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-12-2004, 07:10 PM
  5. In-Dash DWW-7VGA does not fit Subaru Impreza WRX STi
    By LESLIEx317537 in forum LCD/Display
    Last Post: 02-17-2004, 12:25 PM
