so yeah, i lied about not doing work... ive done alot
i have to post pictures and will do that soon, but on friday i measured the speaker wires and cut enough of them so they reach from the center console back through the center console and under the mats to under the back seat, the slack sits there and the rest go up being the backseat (but behind the carpeting in the trunk) and come through a small hole next to the amp where it will be wired in (im waiting for my damn wiring harness for the speakers to be connected and my new speakers [mounted in the rear deck])
then i mounted the amp in the back wall in the trunk, it goes accross the center (tilted down slightly) and connected to the two metal square rods that run down behind the backseat.
i finished wiring the rca cables through the center console, got my carpc running for the first time (almost perfectly.. but two problems... ill talk about those at the end of my post) all the wires now have been run and set in place, i need a new maxi fuse, but until the the one i have it should be ok (its 5 ampre more than i would like, but ill survive)
what else... nothing i guess... ok now for the problems
2 of em, kinda really big ones though
1) my opus 150W PS will NOT turn on my carpc, i have been using a screwdriver, (or one time... my finger) to short the pins to turn it on.... im thinking if the shutdown controller is shot, ill just use a switch i got at walmart for 99 cents (which is very nice and oem looking, so i dont mind)
ok... now the very big and horrible problem...
i think my lilliput is broken, i dont know how... but it is
look closely, the screen is missing pixels in the middle
and if you try to touch it..
about 1/8th of an inch of the screen on the right side is black, and the farest right vertical strip of pixels is very staticy (white pixels flash) also, in the middle of the screen, about 1/8th of an inch is missing, but instead of being black, the right side covers it (i think that the processing for those lines screwed up, causing them not to be rendered... then the other lines take its place, causing the 1/8 of an inch to be blank on the far right... this IS a serious problem, since MY SCREEN ISNT WORKING, but the touchscreen still works like it should (even though there is part of the screen missing, when you touch, it goes to where you click...)
for example about the clicking....
say the screen was working, if you clicked the start menu, it senses it at the start menu...
now for my screen which is broken... although the screen is shifted, the touchscreen seems to be as well... meaning it still goes to the right spot according to the screen, but not where it should IF it worked correcly...
basically everyone on the right of the screen has shifted down to the left.. causing a blank screen on the right....
i dont know if it can be fixed, or how it happend... but i hope mp3car's store will give me a refund or replacement, because this is unacceptable.
edit: fixed a typo
LinkBack URL
About LinkBacks
(and on saturday i found out just how good that line is...)
