Results 1 to 4 of 4
Thread: Audio Upgrades - Infiniti QX4 - 02 - In Progress
    Jun 2006
    Any help/suggestions appreciated. Just able to replace 2 rear OEM speakers with Alpine components, but I don't know if I should leave tweeters alone or use crossovers for new speakers? and where should tweeters be since there's no OEM locations for rear tweeters? and will the OEM Bose be able to handle these new speakers (rated 70rms/350max) once front & rear components are in?
    Apr 2005
    the rear doesn't need tweeters. the sound is meant to be coming from the front, that's why people put components at the front. If you've already bought the alpine components ffor the rear (is that what's in the pic?) then juts don't connect the tweeters. that way you're not hearing any high frequencies from behind you.
    as foir the Bose being able to handle it, it's the other way round. the speakers need to handle the Bose. and they will they're designed to work with an amp so they'll handle more power then you'll be giving them.
    Jun 2006
    Quote Originally Posted by rudeboymcc
    From the wiring diagrams, i think Bose has amplifiers for front & rear speakers, but don't know the specs (as always with Bose!).
    Is there a way to add an amp w/ OEM headunit?
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    yes, most amps have a hi-level input where you can just connect the stock stereo's wires to instead of using rca's, i've never heard how this comes out, but your prob better off using the rca's of a aftermarket, or a computer
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
  1. OEM Navigation Connectors
    By Mr Castulucci in forum General Hardware Discussion
    Last Post: 07-20-2010, 06:25 PM
  2. Audio problems, Epia Sound, and FAQ stuff
    By gothate in forum Newbie
    Last Post: 06-16-2005, 05:04 PM
  3. Replies: 19
    Last Post: 12-04-2004, 06:37 PM
  4. XMDirect Digital Audio Project ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 10-11-2004, 10:26 PM
