+ Reply to Thread
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: 2000 Chevy S10 Xtreme - TruckputerX
    Variable Bitrate xs10x's Avatar
    Jul 2005
    Bronx, NY
    Cool 2000 Chevy S10 Xtreme - TruckputerX
    I hope you enjoy my phase 1 setup.
    IN-CAR ENTERTAINMENT SYSTEM - TruckputerX
    - Dell Optiplex SX270 / XP Pro
    - 2.8 GHZ / 1 Gb ram / 160Gb HD / CDR-DVD
    - RR Enabled / Tweaked
    - Xenarc 700IDT
    - Aims 600 Watt pure sine inverter
    - Mp3 | DVD | GPS | AM/FM
    - Bluetooth - WIFI 802.11g Enabled
    - (2X) Game elements usb recoil controllers
    - Game Emulation - N64 / Nes / Snes / Gb / Sega
    - Apple Bluetooth Keyboard
    Powered By:
    - Rockford Fosgate FRC4246 4X6 (Dash)
    - Rockford Fosgate FRC3205 5 1/4 in the Q-Form kick panels
    - Rockford Fosgate T162C 6-1/2" 2-WAY SPEAKERS on the Doors
    - Rockford Fosgate FNQ4401X Fanatic Q 1" Component Tweeters
    - (2) Rockford Fosgate Punch P4004 4-Channel Amp
    - RockfordFosgate 3812z [2] 12" Subs w/Enclosure
    - RockfordFosgate PowerSPL wire kit
    - Tsunami Digital Battery terminals +BT10MP/-BT10N
    - (2) Optima yellow top Battery in a Tank circuit
    What can the system do?
    - Navigation & Mapping - Completed
    - Bluetooth Phone Integration - Completed
    - HD Radio - In Progress
    - OBDII Vehicle Diagnostics - Completed
    - Indash Touch Screen Control - Completed
    - CD player/MP3 Extraction - Completed
    - MP3 Player - Completed
    - AM/FM Radio with TimeShift and Recording - Completed
    - DVD/Video Player - Completed
    - Picture Viewer - Completed
    - WiFi Sync Support - Completed
    - Speedo | Compass | Clock - Completed
    - Front / Rearview Nightvision camera - In Progress
    - GPSGAS - Finds Cheapest Gas Station in area using GPS/WiFi - Completed
    - Calender with Todo and Events - Completed
    - Car Maintenance Program - In Progress
    - Weather updates with 5 day forecast and dopler - Completed
    This is my billet flamed pedals / Q-Form kickpanels and RF door speakers
    My custom power switches for the (Red) 600Watt Pure Sine Power Inverter and (Blue) (2) 4 Channel Rockford Amps and two USB Ports
    My overhead console
    A pic of inside my cab with the TruckputerX
    Dell SX270 flushed into my center console with AC and a Trackball mouse
    Pic of my bass knob inside my overhead console
    In this pic if you look carefully you will see the Belkin 7 port Powered USB Hub just above the kickpanel speakers
    The next two pics are of my two Optima batteries (Tank Circuit) which powers everything from my Power Inverter/ Amps and Dell SX270
    `¨`¨`¨`¨` _____||¯.\__
    .:.:.:.:.:.:;!_(o)______(o)'i
    TruckputerX - Vortech SuperCharger Vid
    TruckputerX Progress Bar [|||||||||-] 90% Complete [It's never 100% done]
    _
    Mar 2004
    Little Elm, Texas
    interesting integration.
    is that a track ball in the center console?
    also, hope you never plan on competing in any SQ events with that battery there....
    there's a reason all batteries mounted inside the cabin of a vehicle must be sealed off and vented to the outside...
    who did the install of the system and the PC?
    Jan Bennett
    Jul 2005
    Bronx, NY
    Quote Originally Posted by Red GTi VR6
    Yea thats a kensington trackball mouse. I use the top two buttons for volume up and down. Press both together and it mutes the system.
    Whats the reason for the Battery to be sealed and vented to the outside? Gas when charging?
    Do OPTIMA batteries ever produce gas?
    When used with a properly regulated constant voltage charging system (such as an alternator), the OPTIMA battery will normally not produce hydrogen gas. Occasional gassing can occur when charging at higher voltage levels or in extreme high temperature conditions. In automotive applications this typically will not happen if the alternator/regulator stays below 15 volts.
    _
    Mar 2004
    Little Elm, Texas
    yes - they can produce gas if they are punctured or soomething happens and they overheat.
    TYPICALLY won't happen is a TYPICAL response, what seperates a good system from a great system is usually when you consider what MIGHT happen. There's a reason it's a rule in USACi and I'd imagine in just about any other sound organization.
    I went through the same questions when I had my first SQ system with a battery mounted in the spare tire well in my hatch back. I would argue with the judges that it was a pointless rule over and over again until I finally had a judge that was intellegent enough to explain it to me.
    ALL batteries produce gas, they just do it at different levels.
    It's not exactly something I'd like to take a risk at....lol
    again, if you're going to compete, it's a heads up, if you could care less otherwise, then I could care less!
    Just thought I would point it out since you've obviously put a lot of time, money, and thought into this truck.
    Jan Bennett
    Jul 2005
    Bronx, NY
    Cool. I appreciate the info.
    This is still the first install that was rushed for the show season. I have to relocate some hardware around anyway.
    _
    Mar 2004
    Little Elm, Texas
    what do you compete in?
    car shows?
    what shows do you make it to?
    wondering if we might possibly cross paths in the future, I'd love to see your set-up in person!
    I'll be making it to Texas Heat Wave, Arkansas Blast, USACi world finals in Kansas City, and IASCA finals whenever they get their act together and announce a date and place...lol
    Jan Bennett
    Jul 2005
    Bronx, NY
    car shows?
    That would be awesome, But I don't think my audio is competition stuff.
    I am looking to go to Nopi Nationals this year in Atlanta.
    Variable Bitrate AlienEclipse's Avatar
    Jul 2003
    Dunedin - New Zealand
    I love it!
    That is truely one beautiful truck.
    Keep up the good work!
    We are, will have and forever will be...
    But not tommorrow!
    Dec 2005
    Iowa
    Looks like youve got your stock alernator in your Dime. Is that true?
    I've been wanting to put a carputer in my Blazer but wasnt sure if I'd need a new alternator. I thought about upgrading the alternator but wasnt sure, I knew either way though I'd have a tank circuit.
    Jul 2005
    Bronx, NY
    Yes it's true. Still the factory non modified alternator. Even though it's working great, I still plan on upgrading it to a 200 amp alterantor. Don't want to put too much stress on it.
+ Reply to Thread
  1. chevy mp3 s10 ;)
    By PHiLiSO in forum Show off your project
    Last Post: 06-03-2009, 02:46 PM
  2. 2000 Chevy Silverado
    By gottifour in forum Worklogs
    Last Post: 09-11-2006, 09:44 PM
  3. 2002 Chevy S10 ZQ8
    By slick rick in forum Worklogs
    Last Post: 05-08-2005, 09:27 PM
  4. 2000 Chevy Tracker Glove Box PC
    By nijel in forum Show off your project
    Last Post: 11-16-2003, 09:04 PM
  5. 2000 S-10 Xtreme Install
    By FreznoSmooth in forum General MP3Car Discussion
    Last Post: 07-17-2001, 01:02 AM
