Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: 95' Saturn Sedan
    Newbie techyguru's Avatar
    Nov 2005
    Bloomington, MN
    95' Saturn Sedan
    Two new pics at bottom of post
    Car: 1995 Saturn Sedan SL1
    Mileage as of 6/06: 176,000 Miles
    Car cost: $1000 3 years ago
    Motherboard: VIA EPIA M10000 Mini-ITX
    Power Supply: M2-ATX 160W Intelligent DC-DC PSU
    Ram: 512MB PC2100 DDR266
    Screen: Lilliput 7" VGA Touchscreen 629GL-70NP
    OS: Windows XP SP2
    GPS: Rikaline 6010 USB GPS Receir
    WiFi: Hawking Technologies HWP54G PCI Card
    Antenna: MFJ-1800 2.4 GHz WiFi 15dBi Yagi Antenna
    This is my Work Log
    The PC is mounted under the passenger seat and can not be seen with the seat in. Power is taken from the cars battery, yes it's fused and is large enough wire... All wiring is hiddn and I wasn't going to take it apart just for this thread.
    And now for everyones favorite part... The Pics!
    My car, at least it runs well.
    This is how it looks while I'm not there. Normally the bezel is pushed further in but I didn't have it screwed in when I took the pics.
    Like everyone says, it looks better in person.
    Now I don't have any expendable income for a internet connection in my car and untill I see something affordable I'll stick with this when I need it, a nice dirrectional wifi antenna.
    Let me know what you think.
    New PICS
    The dash peice after a bit more work and sitting where it should.
    And a pic that is a little further back, yes I know I need to dust my dash off.
    And thanks to DarquePervert for the link to the antennas, I have one now mag-mounted on the trunk.
    Mar 2004
    what is it? ....
    Variable Bitrate 4u2n's Avatar
    May 2004
    Denmark
    I think you have work to fast with the dash instalation..
    Plan for project = 100%
    Part the project. = 100%
    Built...................= 99%
    Finish.................= 99%
    Install ...............= 99% -50%
    Ditail at 4u2n.dk
    Here
    Newbie FelonyJake's Avatar
    Apr 2005
    UpState NY
    I bet you get better reception with that antenna then anyone else...well when you point it at the right source.
    maybe you can put a rotator like for an external tv antenna. then you can turn it from inside the car with out getting out.
    _
    Mar 2004
    Little Elm, Texas
    wow - that dash - is well - um - yeah....
    any plans to clean that up a bit?
    Jan Bennett
    Nov 2005
    Bloomington, MN
    Yeah, more sanding and a better paint job is for sure on its way, but I don't know about how much else.
    It was my first time using fiberglass and I couldn't stand not having it painted because it would reflect light onto the screen.
    I will get new pics up soon with it smooth and mounted right.
    Any other suggestions?
    Elsewhere
    There are better hi-gain Wifi antennae that are far more suited for vehicle use, not to mention far more aerodynamic.
    Try here: http://www.hyperlinktech.com/web/mobile_antennas.php
    I'm considering the HG2405MGU.
    How about the Wiki?
    _
    Mar 2004
    Little Elm, Texas
    just sand and reapply and sand and reapply and keep doing it till you think your arm will fall off and keep going...lol
    Jan Bennett
    Constant Bitrate Eternalodyssey's Avatar
    Oct 2005
    St. Louis, MO
    Wow, that was very interesting, defenitely more sanding a little bondo might do the trick for that dash peice. Perhaps you might want to consider moving(sanding) the top of the dash peice down a bit so that you can see the bottom of your screen. Its a good start thought and defenitely a step in the right direction.
    Check out the updates. Project 2003 Dakota worklog: http://www.mp3car.com/vbulletin/worklogs/85490-project-2003-dodge-dakota.html
    IS JACK BAUER GONNA HAVE TO SMACK A *****?
    Newbie pikers's Avatar
    Jun 2005
    Is is April 1st again? Love the HAM radio ****z on the roof.
  1. 95' Saturn Sedan
    By techyguru in forum Worklogs
    Last Post: 06-20-2006, 11:25 AM
  2. 2004 Saturn Ion Sedan
    By elmo_eats_rust in forum Show off your project
    Last Post: 02-05-2005, 03:34 PM
  3. 95 Saturn SL2 Install
    By Tuanies in forum Show off your project
    Last Post: 09-15-2004, 10:36 AM
  4. Saturn VS. Toyota
    By lstrunk in forum Off Topic
    Last Post: 06-27-2002, 03:41 PM
  5. 95 Lite?
    By gizmos in forum Software & Software Development
    Last Post: 08-03-2000, 01:29 PM
