Page 5 of 13 FirstFirst 12345678910111213 LastLast
Results 41 to 50 of 122
Thread: 2002 Suzuki Aerio SX
  1. #41
    _
    Mar 2004
    Little Elm, Texas
    you need a heat gun to shrink the wrap around the joints. Slide them over the wire, over hte joint, then aplly heat, they will shrink.
    Jan Bennett
  2. #42
    Constant Bitrate seanshine's Avatar
    May 2004
    Behind the Zion Curtain
    Quote Originally Posted by DavidIQ
    Ok...so I was supposed to do this during the weekend but didn't have time so I'm proposing myself to do this THIS weekend. But I have a question:
    I bought these shrink wrap things and have no idea what to do with them or how to install them I searched around on Google for some clues for a bit but couldn't find anything useful.
    After you have your two wire ends bare and ready to solder,cut a length of shrinktube that's going to be long enough to cover the joint and slide it onto one wire,(back about an inch or two so the heat from the soldering iron doesn't shrink it first) solder your wires,slip the shrink over the join......and grab a $1.29 bic lighter and play it a few inches away from the tube until it shrinks.You could use a heat gun as Red suggests,as well.
    Any sufficiently advanced technology is indistinguishable from magic - Arthur C. Clarke
  3. #43
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    If heat gun is not available, use hair dryer and set to hot (I only use it once).
    Quote Originally Posted by seanshine
    I use that method all the time but not a BIC lighter. That too expensive for me. 5/pack at 99 cents store work fine.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  4. #44
    _
    Mar 2004
    Little Elm, Texas
    one issue with flame is that you really risk burning a hole in the shrink tube. it CAN be used, we've done it before in a pinch, but it's no way to properly do the install. A heat gun isn't all that expensive.
    Jan Bennett
  5. #45
    Low Bitrate DavidIQ's Avatar
    Jun 2006
    Clearwater, FL
    Well I did it this past Friday. Just hadn't had the chance to report back. I used my wife's hair dryer
    And here's the end result:
    A lot less noise coming from the speakers so it all worked out great. Thanks guys for giving me that push.
    -David IQ
  6. #46
    _
    Mar 2004
    Little Elm, Texas
    100% better!
    congrats on getting an added benefit out of it too!
    happy to see it all worked out for you.
    Jan Bennett
  7. #47
    Variable Bitrate portabuddy's Avatar
    Feb 2006
    mississauga, On.
    OMFG I JUST BLEW MY LOAD!! PERFECT
    Life Dosn't come with a reset button, if it did you might as well turn the game off.
  8. #48
    _
    Mar 2004
    Little Elm, Texas
    woah portabuddy.....calm down there d00d.
    it's just some heat shrink and solder...
    Jan Bennett
  9. #49
    Das
    Das is offline
    Constant Bitrate Das's Avatar
    Aug 2004
    Texas
    Here you go...
    First off, I used speaker wire, second off I am stupid
    AND it was fused.
    It fryed the power and ground wires, but look where it goes from speaker wire to electrical wire (red).
    Flame on
  10. #50
    _
    Mar 2004
    Little Elm, Texas
    that's classic!
    Jan Bennett
  1. What's with the sudden flood of newbs?
    By ShinkunoNamida in forum Off Topic
    Last Post: 03-29-2007, 02:43 PM
  2. VW Golf TDi MK4 2002 ODB cable confusion - which one is the right cable?
    By f1lby in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-19-2007, 08:19 AM
  3. 2002 Toyota Camry with Navigation Reuse Screen
    By PowerRock in forum LCD/Display
    Last Post: 02-10-2006, 09:38 PM
  4. Jeremy's Aerio SX Car Computer with SIRIUS, XM & GPS!
    By fromplanetbob in forum Show off your project
    Last Post: 07-10-2005, 09:42 PM
  5. Suzuki Aerio SX (Wagon) Install
    By fromplanetbob in forum Worklogs
    Last Post: 05-22-2005, 01:06 AM
