Page 2 of 18 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 177
Thread: 2007 Tahoe install
  1. #11
    Maximum Bitrate Naamanf's Avatar
    Sep 2003
    Colorado
    The two black go to ground, the two yellow go to constant 12v. Red is 12v turn on signal. Blue is 12v out to turn on amps or trigger a relay.
    2007 Tahoe
    Opus with iBase 896 and Pentium M 735 Transflective Xenarc Alpine DVA-9861, PXA-H900, Sinfoni 45X2 (2) 90x2, Genesis Dual Mono, JL 1000/1 (2), Focal Be tweeters, ScanSpeak Revelator Mids, Dynaudio MW170, Dayton 12" Ref.
    My Install
  2. #12
    Jul 2006
    Quote Originally Posted by Naamanf
    so its connected straight to the battery of the car?
    wont the battery get drained like this?
    sorry jus new to this stuff.
    nice install btw, one of the best ones ive seen so far..
  3. #13
    Sep 2003
    Colorado
    Thanks. It really depends if you use standby and how long you go between starts. I have never had a problem. If I was going to be away I would just open the circuit breaker (or take out the fuse if you go that route) from the battery. You are more likely to drain your battery having the computer on. I now use two batteries so it's not an issue.
    2007 Tahoe
    My Install
  4. #14
    _
    Mar 2004
    Little Elm, Texas
    Ummm yes, maybe, sounds good, and don't know. I really don't know what class I should be in. I have never competed so I really don't know what to expect.
    ahh - well I HIGHLY suggest it. Since I've been competing I've gained a whole new appreciation for this stuff. And no, it's not because I like to hear from other people about my car like some people seem to think.
    I like the challenge.
    I'd recommend starting off for a show or two in the Basic class and just give it a go, you might just get bit!
    to adeel: the only reason you would kill your battery is if you didn't utilize the shut down features that these PSUs have built into them. You have 3 options (technically 4 I guess)
    • Shut down completely
    • Hibernate
    • Stand-by
    • leave the PC running like normal
    Jan Bennett
  5. #15
    Das
    Das is offline
    Constant Bitrate Das's Avatar
    Aug 2004
    Texas
    Someone has too much money!
    Looks good though.
  6. #16
    Sep 2003
    Colorado
    Not really. I am just a E-Bay slut.
    2007 Tahoe
    My Install
  7. #17
    Sep 2003
    Colorado
    More pictures.
    2007 Tahoe
    My Install
  8. #18
    Sep 2003
    Colorado
    Midbass speakers in the doors. Dynaudio MW-170. Still need to deaden the doors.
    2007 Tahoe
    My Install
  9. #19
    Sep 2003
    Colorado
    Sub enclosure.
    2007 Tahoe
    My Install
  10. #20
    Sep 2003
    Colorado
    JL 10W3v3
    2007 Tahoe
    My Install
  1. '02 Tahoe Install: 8" In-Dash TC, only cosmetics left!
    By PutterMcGavin in forum Worklogs
    Last Post: 12-26-2006, 12:24 PM
  2. Tinyxp vs nlite vs sensible install
    By geeky_hawkes in forum WinNT Based
    Last Post: 06-15-2006, 04:55 PM
  3. Starting MM trys to install IntelPROset software?
    By sturmovik in forum Map Monkey
    Last Post: 06-03-2006, 03:20 PM
  4. windows xp install
    By Moneyfink in forum WinNT Based
    Last Post: 03-09-2005, 01:05 AM
  5. How to install 98lite?
    By ugosplat in forum Software & Software Development
    Last Post: 07-27-2003, 06:40 AM
