Results 11 to 20 of 23
Thread: My Festiva Car PC (3500+ watts of audio)
  1. #11
    Constant Bitrate fooshizn1x's Avatar
    May 2005
    714 - Socal baby!
    Quote Originally Posted by xpnsyd View Post
    The system is run on a separate circuit from the car.. I fabbed in a 160a one wire alternator as a second alternator.
    First off, thats a hefty amount of equipment for a festiva, congrats!
    but....
    I have a small pet peeve with "one wire" alternators, and considering you've put quite a bit of money into your install you may want to reconsider the one wire thing and go back to (or switch to) a 3 wire alternator.. most stock 3 wire alternators actually put out MORE than those higher amperage single wire ones...
    http://www.madelectrical.com/electrical-tech.shtml
    Instead of linking directly to the "one wire vs 3 wire" article, I linked to a page with several articles of good information... Checkout the article, I think you'll be suprised.. I know I was until I read it, then did my own testing, and was shown the light..
    Sell me your stuff.. please see what i'm looking to buy
    http://mp3car.com/vbulletin/showthread.php?t=75182
  2. #12
    Newbie xpnsyd's Avatar
    May 2006
    Quote Originally Posted by fooshizn1x View Post
    but....
    Not a Festiva alt.. the wiring is way too small to pump high amperage through..
    I have seen those that have tried to upgrade the Festiva alt with stock 90 amp alts make fires and burn up the dash. Upgrading the Festiva alt is just too dangerous.
    BTW, I'm not a youngin, (over 40) and while some of that may be true in that article, it mostly looks like an explanation on why to buy their product. And to say the reason people buy 1 wire alts is because they must not be smart enough to figure out how to wire a 3 wire alt. BAH!!
    1. I don't need a dummy light, My caps have meters in them and if it stops charging, I will know and with the industrial dry cells that are meant to be discharged, it hurts nothing. If it starts over charging, I can simply turn the car off and disconnect the wire from the batteries without even exiting the car.
    2. I don't need stringent remote sensing. This is a 2nd alt on a separate circuit. So as long as it senses when the batteries drop below a certain voltage and starts charging, and turns off when the batteries are charged, that's all I want.
    3. The alt charging wire is a 1/0 and being in a Festiva it is shorter than almost any other car.
    4. The alt is on it own pulley and if it tosses a belt the dry cells will drain and at most they would have to be recharged to 9v before the 1 wire would start charging again.
    I have used both 1 wire and 3 wire alts over the years and yes the 3 wire is better for for general single alt car apps. But my charging system was designed to charge the batteries not, run the equipment.
    I can run my whole system without the engine on for about 4 hours without dropping voltage enough to require a charge. So, unless I am on a long trip, or hitting it hard (which I then can't be in the car or I'd go deaf) charging is not a problem. I also have a 50amp 120v battery charger in the back of the car if I need more engine off time..
    Needless to say the 160a alt and 2 industrial dry cells are overkill for the amount of things that 1 or 2 people can do at one time. All the while my tiny 50a Festiva alt runs the car and it's normal electrics just as it did before the system went in.
  3. #13
    May 2006
    Quote Originally Posted by FC3S View Post
    i'd like to know why your watching xmen 3
    its not out on dvd yet
    illegal~~ :P
    That's a trailer...
  4. #14
    May 2005
    714 - Socal baby!
    Well thats pretty much the standard answer that most people give when they still think the 1 wire is better. that place isnt trying to sell any special product besides a wiring harness for those who are upgrading, adding to a vehicle without the proper wires already, or for those who are unfamiliar with how to install it. The charging capacity, and the way it charges are far superior with a 3 wire.. but if the 1 wire is working for you suffeciently, then I guess thats all that matters. Good luck with your project, I too would like to see it all finished up!
  5. #15
    Jan 2006
    I'm an electrician and after reading that website you linked to, I saw no evidence of a 3 wire alternator being better than a 1 wire. I attempted to find somewhere on my own that shows 3 wire alternators being better than 1 wire, but couldn't find anything.
  6. #16
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    That's a trailer...
    sure
  7. #17
    May 2005
    714 - Socal baby!
    Quote Originally Posted by Namor View Post
    That makes two of us, I'm an electrician too, that fact doesnt mean that you should "get it automatically" 277/480 VAC has nothing to do with 12VDC. I'll just say that you either didnt read all of the articles (many have good pieces of information that any automotive enthusiast should know) or you didnt understand them. Either way, doesnt really matter... people will use what people want regardless.
  8. #18
    Jan 2006
    The only thing is, I'm not a home electrician like you may be thinking. I'm an electrician in the Navy and we deal with both AC and DC and motors/generators in particular. And the simple fact is, the that link gave no proof. I was expecting comparisons of sine waves between the 1 wire and 3 wire, but either way its being generated by a 3 phase AC generator. So you will get the same output.
  9. #19
    Maximum Bitrate yrean's Avatar
    Apr 2006
    Chicago
    ummm besides it being Way rough..... where did you move the climate control to? or did you just decide you didnt need those anymore?
    MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
    M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
    7" Lilliput 619 | WinTV | WIFI | Bluetooth
    Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
    Roadrunner | LSXvoid | IGuidance 3
    My Worklog
  10. #20
    May 2006
    LOL.. Festivas really didn't have a "climate control" unless it came with A/C.. meaning all the movable vents on a Festiva are only for A/C. Other than that there is only defrost and heat which only comes out at the top and bottom.. so I just set it on defrost and relocated the fan switch to the oem lighter hole and added a new lighter section from another dash. Works well, I just went through a big rainstorm and it worked normally. Besides, I've lived in south Texas almost all my life and am used to the summer heat..
  1. Car power supply (battery charger) from old pc supply
    By stimps in forum Power Supplies
    Last Post: 08-20-2010, 12:39 AM
  2. Attention Newbies! A FAQ to the FAQs
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-15-2006, 11:17 PM
  3. Car 5.1 Dsp Options Vs Pc 5.1 Dsp
    By port20 in forum Car Audio
    Last Post: 05-29-2006, 02:10 AM
  4. Replies: 16
    Last Post: 03-14-2006, 08:47 AM
  5. In progress car PC install.
    By Arathranar in forum Fabrication
    Last Post: 10-20-2004, 12:49 AM
