WOW!!! That is a beautiful work of art![]()
but for now I have no furthur or useful input. lol Peace...
Hi all,
Had my Supra for about 1 year now been using the in car set up basically as i got it running Media software & being a semi computer wiz kid not set it up to all the latest uses that are on the go now.
All that i have been using it fow is basically playing mp3's
Things that i would like to have done are as follows :
1.Have a decent upgrade to like RoadRunner that's most are using now.
2.Have a decent 3D Navigation programme running on it similar to the latest TomTom's with full UK postcodes & westorn europe installed.
3.What's the best or good small Gps reciever to have.
4.Possible mini cam set up connected so can record car going on the road trips when needed
5.If possible radio stations as well
6.Any other idea's that are usefull to install as well that you recommend.
Ice & Pc specs are:
ICE –
• Front Doors – Rockford Fosgate FNQ 4” Components @ 100w RMS
• Rear Quarters – Infinity reference 6.5” 6510cs 2 way components @ 90w RMS
• Parcel Shelf – Alpine Dual Mag 6x9’s @ 150w RMS
• Subwoofer – Rockford Fosgate power Series DVC 10” sub @ 720w RMS 2 OHM stable
• Rockford Fosgate power series amp for Subwoofer
• 2 x Alpine MRV V12 Amps – 4 channel each to drive the other speaker components
• 1 x One Farad capacitor
1 x Optima Yellow top deep cycle battery
• “0” gauge cable used for both Positive and negative power supply to two 4 port distribution blocks in boot
• Also a “0” gauge ground loop cable installed from boot grounding point to engine bay grounding point to enhance the ICE system ground loop.
• “4” gauge cable used for all amp’s and capacitor power supplies within install
• High grade oxygen free speaker cables
• High grade oxygen free RCA / Phone cables
• Audio Control – Three.1 Crossover / equaliser with built in line driver. It has 2 sets of outputs for HPF range and one set for LPF drives the 3 amps perfectly.
• Head unit = NONE = replaced with an ITX miniature PC housed in standard Head unit location, specs below.
PC Spec’s –
• 1Ghz processor
• 512MB RAM
• 100GB Hard drive
• DVD/CDR-W read / writer drive
• Lilliput 7” widescreen – touchscreen display
• Running Windows XP and Car media Software
• 4 Port USB Hub in boot running – Sat NAV, Sound card to feed Amp’s, Wireless LAN hub.
Also here's a few pic's as well hope you all like
quite interesting hatch area....strange I think is the best word for it.....???
Jan Bennett
Spare tire??? I guess this is more usefull most of the time, looks nice, looks like it would be a target for theives hope you spent the extra and put in a good alarm too.
i haven't ever needed a spare tire....EVER
the one time I've needed a spare...I needed two....
I don't have a spare tire, haven't had one in YEARS
Jan Bennett
I like the idea for the sub, but everytime you want to put it up or down you need to plug the speaker wire or unplug.
nice setup.. but with the rest of the car looking the way it is.. i'd talk some local sound shops into sponsoring a full fiberglassed audio setup![]()
Thank You /////ALPINE
7" Lilli. GPSlim236. Streetdeck. Mappoint. M9000. M2ATX, XMDirect
