Page 3 of 8 FirstFirst 12345678 LastLast
Results 21 to 30 of 76
Thread: I30 Infiniti One Of Kind I Hope :)
  1. #21
    Variable Bitrate Fraychild's Avatar
    Jan 2005
    Somewhere I Belong ~
    Lookin' real clean and nice man - I like that -
    VER. 3.0- Check out below:
    車コンピュータ 3.0
  2. #22
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    Quote Originally Posted by GoHybrid View Post
    while we're on the subject of lights.... this is something i've been wondering... if you put an aftermarket "projector" lens in your car, (i'm assuming this is every headlight that has the dome-shaped lens) does that automatically make it HID compatible... or is there more to it than that?
    well that depends, some lens allow for HID bulbs, do you have the same bulb for driving lights and high beams? because high beams use 360 degre light, driving light get's reflected to the ground, some lenses just set the cut off point higher so it looks like you have a better light when in truth your just ****ing off more ppl, if you really want to make sure do the test i mentioned above, what kind of car is it?
  3. #23
    Low Bitrate I302K's Avatar
    Mar 2006
    NY
    man thats not a test lol. thats to get both head lights even. yes some head lights are diffrent but proper allignment can help. and about u being a mechanic what do u think about putting a 2000 maxima manual trany into a 2000 Infiniti I30
    Xenarc 700TSV - 80GB HD -Xenarc 700TSV - 512MB -BU353 GPS - iGuidance 3.0 - RoadRunner - Opus ITX Mini Vehicle PC Case - Opus 120W - XM RADIO - WIFI - CDR\DVD
  4. #24
    Maximum Bitrate GoHybrid's Avatar
    Jun 2006
    Denver, CO
    Injector - It's a 2005 corolla CE. haven't done anything to the headlights yet, but it's got separate bulbs and reflectors for high/low beams. aftermarket projectors typically include the standard reflector for high beam and a projector lens for low beams.
  5. #25
    Mar 2005
    Rockledge, FL
    Quote Originally Posted by I302K View Post
    i would need years, engine sizes, sub models (lx, gt, etc), FWD or RWD, i can give you step by step instructions with pictures on how to do remove both trannys, just keep in mind that you are going from an auto to a manual, back in the day it didn't matter if you had an auto or manual tranny as long as the car moved, now days trannys have modules, sensors, wiring, harnesses, ecu, everything, so keep in mind is not just, make a hole for the cluch, make sure the bell housing matches and bolt it on.
    do you have a picture of the lens? i mean now days with all the crap you can buy is almost impossible to determine if something is HID compatible unless you can clearly look at it
  6. #26
    Mar 2006
    NY
    i have no comment to the q u asked about the trany what kind of cars do you normaly work on
  7. #27
    May 2006
    nice setup. I think I ill do my install just like your except I would like a bigger touchscreen lets say 8" . Can I pm you to ask you more questions?
  8. #28
    Mar 2005
    Rockledge, FL
    i have 2 jobs, regular vehicle mechanic and duing weekends i do heavy equipment (motor graders, reclaimers, etc).
    basically what i asked you was the information from the donnor vehicle and your cars info, the sub model is gt,lx ,es ,for expample mustang gt has a v8 4.6li engine, and all the options a mustang lx deppending on the year, it has either a 4 or 6 cylinder 3.8li or 2.4li engine, what i mean by the bellhousing is think back to when you where a little kid remember that one game where you had to put in the cylinder into the circle and the cube into the square, same principle applies, the bellhousing is the outside shape or bolt patter on the tranny, that bolt pattern or bell housing has to match your engine pattern, after all you can't put the square into the circle.
  9. #29
    Mar 2006
    NY
    well if u think just a lil bit or do any work on maxima or infiniti u would know they use the same engine 1 to 1 on all models of the same year. so the 2000 maxima and I30 would have the same engine and the same auto trany just infiniti never used to manual trany since its a laxury version of a maxima go figure I actuall know something wow
  10. #30
    Jun 2005
    Washington
    I would take that V1 all the way to the top of your windshield so it is hidden, that way it doesnt bother the view. You can just hook it up to your wipers fuse or smthing. V1's the best!
  1. Replies: 0
    Last Post: 07-30-2006, 08:34 PM
  2. XMPCR...is there any hope?
    By ccrobin in forum Centrafuse
    Last Post: 07-26-2006, 12:00 PM
  3. What kind of power supply does car audio equipment use?
    By Skraggy_uk in forum Power Supplies
    Last Post: 04-11-2003, 11:40 AM
  4. What kind of GLUE???
    By Dimitris1976 in forum General Hardware Discussion
    Last Post: 06-08-2001, 09:58 AM
