Page 4 of 8 FirstFirst 12345678 LastLast
Results 31 to 40 of 76
Thread: I30 Infiniti One Of Kind I Hope :)
  1. #31
    Low Bitrate I302K's Avatar
    Mar 2006
    NY
    its curently hard wired to my cig lighter so it turn on when the car starts i can have it set any higher since it wont have a clear view of the rear window.
    but thanks for the comment
    Xenarc 700TSV - 80GB HD -Xenarc 700TSV - 512MB -BU353 GPS - iGuidance 3.0 - RoadRunner - Opus ITX Mini Vehicle PC Case - Opus 120W - XM RADIO - WIFI - CDR\DVD
  2. #32
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    Quote Originally Posted by I302K View Post
    well if u think just a lil bit or do any work on maxima or infiniti u would know they use the same engine 1 to 1 on all models of the same year. so the 2000 maxima and I30 would have the same engine and the same auto trany just infiniti never used to manual trany since its a laxury version of a maxima go figure I actuall know something wow
    don't be a smart a**, i was just trying to help you out, i don't do half a**ed s**t like that with costumer cars for the simple reason that it's not my car, if something breaks i replace it with the original part not one from another car, yes i understand some components are cross compatible and if i had an infinity or a nissan i would give a f***, and i never said they were not compatible i just said that it would not be easy, and even if the engine is the same the computer could be different, just like in a mitsubishi eclipse GS, 420a motor and 5 different ECUs avalible for the same engine even the same year, same thing with a geo tracker with a 2.0li in it, same engine 3 different choices when choosing an ECU, so just because you know something about YOUR car it does not mean you know everything there is to know, now when you show me a picture of your auto infinity with a manual nissan tranny in it i'll shut up but for the time being, F****.
  3. #33
    _
    Mar 2004
    Little Elm, Texas
    hey hey hey now....tone it down a bit...mkay!?
    Jan Bennett
  4. #34
    Mar 2006
    NY
    Quote Originally Posted by Injector View Post
    don't be a smart ***, i was just trying to help you out, i don't do half assed **** like that with costumer cars for the simple reason that it's not my car, if something breaks i replace it with the original part not one from another car, yes i understand some components are cross compatible and if i had an infinity or a nissan i would give a ****, and i never said they were not compatible i just said that it would not be easy, and even if the engine is the same the computer could be different, just like in a mitsubishi eclipse GS, 420a motor and 5 different ECUs avalible for the same engine even the same year, same thing with a geo tracker with a 2.0li in it, same engine 3 different choices when choosing an ECU, so just because you know something about YOUR car it does not mean you know everything there is to know, now when you show me a picture of your auto infinity with a manual nissan tranny in it i'll shut up but for the time being, **** YOU.
    USING LANGUAGE LIKE THAT IN A FREINDLY FORUM IS NOT THAT NICE!!!! AND IF YOU WANA SEE IT DONE A FEW MOPRE WEEK BABY BTW NOT THAT HARD THE ECU FROM A 2000 MAXIMA WILL WORK LEARN HOW TO TALK WITH OUT BEING RUDE
  5. #35
    Elsewhere
    There are no language restrictions on this forum, I302K.
    Injector, the insulting comments are getting you this warning. Play nice or take a forced vacation.
    How about the Wiki?
  6. #36
    Mar 2005
    Rockledge, FL
    there you go edited w/o the lengauge, I302K when i see the pic of the tranny in with the nissan TCM in it, i'll garatee you i'll eat my words
  7. #37
    Elsewhere
    Again...
    It's not the language, injector. It's the way it was used.
    You can say "****" all you want. Nobody cares.
    But when you start tossing out "**** you", people get offended.
    How about the Wiki?
  8. #38
    Mar 2006
    NY
    are you saying it can not be done?
  9. #39
    Maximum Bitrate GoHybrid's Avatar
    Jun 2006
    Denver, CO
    Injector- i'm afraid i can't find anything but a web picture. What would you/i be looking for if we could see the headlight clearly to determine it's HID suitability?
  10. #40
    Mar 2005
    Rockledge, FL
    Quote Originally Posted by DarquePervert View Post
    Again...
    ok point taken,
    i'm not saying it can't be done, the thing is now days components have to do more than just fit, they have to be compatible, everything now days is computer controlled, let me give you an example 3 weeks ago, i got a 99 VW jetta, it would start go into drive but it would not move, i could see the shifter cable go into drive but when you looked in the gauge cluster the ECU still tought the car was in park so it never realeased the solenoids inside the tranny, can it be done? yes but it might cost you a lot of $$$ or you might end up having to redo most of your electrical system, unless like you said the nissan TCM and ECU are cross compatible with the infinity ECU and TCM, i would go check with the dealer first, or get a pinout of both ECU and TCM and see if the harnesses even look alike.
  1. Replies: 0
    Last Post: 07-30-2006, 07:34 PM
  2. XMPCR...is there any hope?
    By ccrobin in forum Centrafuse
    Last Post: 07-26-2006, 11:00 AM
  3. What kind of power supply does car audio equipment use?
    By Skraggy_uk in forum Power Supplies
    Last Post: 04-11-2003, 10:40 AM
  4. What kind of GLUE???
    By Dimitris1976 in forum General Hardware Discussion
    Last Post: 06-08-2001, 08:58 AM
