Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 48
Thread: 2005 Subaru Forester FXT
  1. #21
    Banned
    Jun 2006
    sinhcredible - If you like the tranny, you would love the GT30R that that thing has pushing 20psi.
  2. #22
    Variable Bitrate Tissy's Avatar
    Sep 2005
    Essex, United Kingdom
    If its any help to you Subaru guys, i've done a few Subaru graphics etc for my Impreza CarPc.
    Most can be seen here:
    http://www.wrx-carpc.co.uk
    Regards,
    Steve
    System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
  3. #23
    Banned
    Jun 2006
    Ok, we finally got the rear camera mounted an fully connected. Below are some pics....comments are welcomed.
    You can barely see the camera from the distance.
    Closer look...
    Much closer...
    This is the push button that will be used to turn on/off the camera when ever needed without having to place the car on reverse... For those that will ask what that device below is, it's the Alcohol Injection controller. We will relocate it in the armrest later.
  4. #24
    Banned
    Jun 2006
    Ok, we finally got the dash piece painted and it came out really nice. It was painted using car paint so it has a clear coat on it as well. We might have to paint the lower pieces a well for it to match nicely. Comments are welcomed.
  5. #25
    Variable Bitrate we87's Avatar
    Nov 2005
    Dallas, TX
    The paint came out great! Looks so factory, its unreal.... Kudos.
    Carputer Progress
    [||||||||||] 100%
    Finally Installed!!
    Everything is in the car and working.
    I painted the cilpboard mount and it looks good.
    Shutdown/Startup is working excellent!
    View My Progress Here
  6. #26
    Banned
    Jun 2006
    Thanks, I'm really surprised how good it came out. Once I get the power/ground distribution block, we will begin to install everything
  7. #27
    Banned
    Jun 2006
    It's been long since my last post. Work, studies, and other things have kept the project slow. We also went through two different GPS software until we ended up the best, IGuidance V3.
    Today we worked on the car all day after having completed the configuration. We got the computer running and it looks great. The fans are a little too loud for my taste so I will see if they can be replaced with much quieter ones. There are a couple of things that need to be done before it's flawless. We will be connecting the sound tomorrow as well. I will take pics of everything tomorrow. The install is very clean and you can only see a couple of wires where the carputer is located....
    Stay tune...
  8. #28
    Jun 2006
    NorCal
    That bezel looks great salvi! Keep up the good work! May I ask where you took it to be painted, or what type of paint you used if you did it yourself?
    That camera is also very well done. What kind of camera is it? Would you recommend it?
    I am still working on my Forester. It is very slow going, especially since I have hardly done anything in the past two months. This past weekend I started working on the recessed floor in the trunk:
    I also assembled and tested my Lilliput in the WRX bolt-in kit:
    I still need to modify the center panel a bit, but I might be able to get by without using bondo if I am careful.
    Let us know how the wiring goes. I'd be interested to see how you do your power distribution.
  9. #29
    Banned
    Jun 2006
    Thanks for the comments. The bezel was painted by a local shop. I think that they used the Subaru color. It won't match exactly to the entirior panels but it's pretty close. It also has a clear coat so it's pretty shiny.
    The camera is the one that is up for sale in the MP3car store. It's really nice and mounting it is easy. The only think that has dissapointed me with the camera is that the outer black rim of it has turned from black to gold , how, I have no clue. It's nice because it works both in the daytime and night time. I would recommend it. I'll take pics of it when I get a chance.
    The power distribution is pretty simple. It's almost the same as the first pic that I posted. I'll take pics of that today and post them as well.
  10. #30
    Banned
    Jun 2006
    About a week or two we completed everything. Here are some shots of the RR front end and the GPS. I'm in the process of taking a couple of videos to post as well
    Custom molded 7” screen, looks better than OEM.
    Turn by turn GPS.
  1. 2005 Subaru Legacy GT install
    By stage3legacy in forum Show off your project
    Last Post: 04-25-2012, 08:33 PM
  2. 2005 Subaru Forester XT dual screens Dialup BEWARE
    By techy101 in forum Show off your project
    Last Post: 11-08-2006, 10:44 AM
  3. 2005 Subaru WRX STi
    By palpullero in forum Worklogs
    Last Post: 07-01-2006, 08:50 AM
  4. Where to DL old version of RR?
    By accentsound in forum Road Runner
    Last Post: 07-12-2005, 01:51 AM
  5. 2005 Subaru 2.5RS... its aliveeee!!
    By wallyman424 in forum Show off your project
    Last Post: 01-07-2005, 01:39 PM
