tag.. gettin a 02 325 soon(hopefully). Love this install
If you are running an amp get one of these. it helps out a TON!.
http://www.newegg.com/product/produc...82E16812162002
If you are not running an amp, check out Zebel's install.
Zebel 2001 BMW 330ci Carputer
Yea it is fiberglassIs that fiberglass
2003 E46 BMW
Lilliput Transflective, GM965 mobo w/ Processor
ELMSCAN 5 USB, Slot load DVD, BU-353 GPS
Everything is for sale.
That's one sweet install! How you finding the CN13000? I'm just after getting one and getting it up and running. Are you running the Lilliput at it's native resolution with it? If so, where did you get the drivers/bios???
THIS MAY BE A DUMM QUESTION BUT WHAT IS THE DAC FOR?![]()
One of the best way to learn is making mistakes, But much better when you learn from someone else mistakes
Looks great, I love that little keyboard/mouse combo.
Looks like half a laptop!
I was wondering the same thing, then found this: http://www.silverstonetek.com/products-eb01.htm
Scroll down a bit...
great I want one of those Umm.. I have to figure out how to power it on the car but I still one it![]()
It seems to be powered by the USB connection Perrosky! This looks very good! I do have a similar box from Xitel (Pro Hi-Fi). The sound quality that comes out of the Xitel is unvelievable!
lfilomeno the one that you got looks to be more easy to set up in a carputer, are u using it at home or in your car?
I was using it on my CarPC. It is very easy to setup: Connect to any USB port and connect the RCA or Digital cable out to the car AMP. The only downside (and an annoying one) is that the Xitel is discovered simply as an “USB Audio Device”, and bypasses the carpc volume control, providing fixed level output. I could not control the volume from the PowerMate or the up/down controls on my Frontend! I could only control them thru the mixer, Wav controls. But the Silverstone EB01 on the other hand behaves more like most USB audio devices. While it uses the system USB Audio driver, it is detected by the CarPC as “USB Speakers”. The system volume control still works, and has to be cranked to provide line level output, just like a regular radio volume control. Once I receive it, I will let you know how it works. Right know, I have the CarPC sound off the on-board card. IT does sound o.k. after some tweaking but their is some noise from the mobo. Nothing comapres to the sound obtained from the DAC!
