A little embarrasssed with my 'project' compared to all the other ones with fancy new dashes, etc., but it works!
Main reason for a carPC was the need for a larger screen for the GPS. We do a lot of serious offroading in the desert and GPS is a must.
When installing the kit, I did not want to make a lot of modifications to the car before testing everything in extreme conditions (desert driving with temperatures in excess of 140F/60C). I hardly have any tools, no workshops and the supply of these are very limited here.
For the screen I choose a Xenarc 8", since it was one of the brightest around. I did not use the touch screen version, because it will make the screen darker and will increase glare.
I mounted the screen in the empty DIN slot beneath the radio with two pieces of metal. The screen is attached to a ballhead that came with the screen. Added advantage of this position is the instant cooling from the AC. I had it mounted on the dash and within 30 minutes the screen was too hot to handle. The mount held up very well last weekend during a test drive. Jumping over dunes causes a lot of vibration and shocks, but everything worked fine.
Direct sunlight on screen, running NRoute
Direct sunlight on screen, running Ozi
On the console, I installed a mouse. It's the place where the right hand is most of the time when resting.
I have two keyboards in the car. A small keyboard with all keys in the back of the passenger seat and a mini keyboard for some fas tinputs in the front.
As GPS antenna I choose the Holux Slimline 236. This antenna is connected with the PC using bluetooth, but you can also use a datacable. The datacable also charges the unit.
A powered USB hub, mounted on the back of the center console for easy access, gives all the opportunity for other devices.
I chose the Ampie as PC housing and decided to order it with everything mounted and factory tested. Since I need to order everything form abroad, I wanted to limit risks of some items not working. Took me two hours to get the stuff released by customs. First time they saw a device like this and they were highly suspicious![]()
The PC is mounted under the passenger seat. Still need to do some housekeeping on the wiring here.
The PC has it's own power supply. I have connected the screen and hub to another power supply. Not really necessary, but it's nice to have a spare. I have not connected the power to the ignition, but both supplies have that capability with auto shutdown controllers. Both power supplies are connected to a second battery.
The audio from the PC is routed with a device called Car2PC. Basically it cheats the car radio by imitating a CD player. A plugin for Windows Mediaplayer takes care of the controls, so you can still use the controls on the car radio.
As navigation software I use Ozieplorer with moving map and Garmin NRoute. Both work simultanious thanks to a little piece of software called GPSgate. It emulates Garmin to one COM port and NMEA to another.
I found NRoute great for the road. It comes with route planning, audio signals, etc. Ozi is nice for the desert.
Still to do:
- high speed internet access: waiting for a second SIMM card
- webcam for video streaming
Note: sorry for the sloppy pics![]()
