Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
Thread: 1998 Volkswagen Passat
    Maximum Bitrate Mañana's Avatar
    Jul 2004
    Sweden
    We'll, new car means new carputer =D
    When I got the car it had a 1-din stereo in it, but as I wanted it to look as OEM as possible I got hold of a 2-din module and "just" (some adjustments) swapped it.
    I've built a 2-din module for the Xenarc in 4mm plexi, will upload better photos of it later.
    Carputer hardware is as follows:
    Xenarc 700TSV
    Epia M10000
    512mb ram
    Opus 120w
    60gb 2.5" HDD
    BU-353
    Netgear WPN111
    D-link DBT-120
    Most of it it from my old carputer, but wlan and bluetooth has been added.
    I'm using standard WinXP Pro (swedish) with standby. I'm running FreeWay as frontend, and FreeDrive for gps.
    The carputer itself has been mounted in the sparewheel compartment, together with my amps. It has one vga and one usb cable running to the front. I had to rip everything out...
    Mounting of Mobo, HDD and PSU.
    "Finished" mounting of amps and carputer. All cables has too be shortned thou. All of it is 10mm plexi. The 400w amp drives 4 1/2" tweeters and 4 6.5" midrangers (placed in the doors). The other amp is 2x400w, bridged to 1x800w, and it drives a 12" MDS X-MAX sub.
    Finished:
    Elsewhere
    Very clean....
    How about the Wiki?
    Jun 2005
    Washington
    nice oem look
    Variable Bitrate 4u2n's Avatar
    May 2004
    Denmark
    more proto of the computer install
    Plan for project = 100%
    Part the project. = 100%
    Built...................= 99%
    Finish.................= 99%
    Install ...............= 99% -50%
    Ditail at 4u2n.dk
    Here
    Jul 2004
    Sweden
    Yeah, have added some now =) When I first posted this I noticed I didn't have any of the finished install, so I took some today.
    Mar 2006
    Sweden
    tjena
    Hur klarar sig skärmen under vintern i kylan? Det är ju ett jätte stort problem att lösa. Jag kör med avtagbar skärm, det är ju ett måste!
    Vart hittade du kartorna över sverige? har du köpt dom eller "hittat" på nätet? Ge gärna länk om du "hittat" dom
    tack
    Jul 2004
    Sweden
    tjo!
    Den klarar sig utmärkt. Har kört med den två vintrar redan, och det funkar perfekt. Den är dock lite långsam innan den blivit varm, men det tar högst några minuter.
    Kartorna hittade jag för länge sedan, så har tyvärr ingen aning om var de går att få tag på. Det är typ 2001 års kartor eller nått sånt :P Haha...
    Jan 2004
    Har du en plan af dit beslag? altså med mål, overvejer at lave noget ligende til min passat http://www.bilgalleri.dk/html/gal_visbil.asp?ID=57519
    Jul 2004
    Sweden
    tyävrr inte =/
    May 2006
    whered you mount your GPS receiver at?
  1. Volkswagen additional bezel for TMZ lilliput
    By judoGTI in forum Fabrication
    Last Post: 07-23-2007, 12:38 PM
  2. Display Info - 2000 VW Passat
    By jrdwiz in forum Newbie
    Last Post: 05-02-2007, 09:57 PM
  3. 06 vw passat wiring harness
    By dirtylarry in forum Car Audio
    Last Post: 06-09-2006, 11:36 AM
  4. Passat Dash Install Sale
    By passatie in forum Classified Archive
    Last Post: 11-16-2005, 04:16 AM
  5. 98 Volkswagen Passatputer
    By BoyNextDoor in forum Show off your project
    Last Post: 04-24-2005, 11:58 PM
