Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 51
Thread: First Ford Escape XLS with CarPC -
  1. #31
    Variable Bitrate Fraychild's Avatar
    Jan 2005
    Somewhere I Belong ~
    Ha ha ha! Yea man -
    I've been thinking a lot about switching to Street Deck, seems to be a hella' nice software to use in the ride - Problem is, for the $200... I dunno man - That's $$$ -
    Either way, RR has been great so far, skinnable and free - Can't complain!!
    VER. 3.0- Check out below:
    車コンピュータ 3.0
  2. #32
    Variable Bitrate afterdigital's Avatar
    Aug 2006
    New Ro, NY
    have you used blue devil skin created by JohnWPB?
    CTS 05, Mobile Information Center...
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    5.6" Screen (overhead) w/reverse capability
    Finished Project
    Car Hacking
    WorkBlog
    Video
  3. #33
    Newbie kenpojoe's Avatar
    Jul 2006
    Southern Cal
    Dude, sweet install! I dig on what you did with the USB hub. Looks totally factory Keep up the good work.
    01 Solara
    Lilliput 7"
    Jetway 1.5 GHZ C7 mobo
    512 DDR2 533
    M2-ATX, Csetrnc/Morex 2699R
    MPnt GPS
    SD F End
    WiFi
    BlueTooth - not working though
    ALPINE MRP-F250 4/3/2 Channel AMP
    http://www.mp3car.com/vbulletin/show...733#post917733
  4. #34
    Jan 2005
    Thanks man -
    I'm currently using my own modified version of the "Digital Graphite" skin for RR - Man, it's Bad-@$$... Love the skin and cannot find myself using anything else -
    I tweaked it a bit so the main Menu has a Ford logo, which is also used as a "Play/Pause" function, I added "Volume" buttons, and a larger time/clock display...
    Also bigger fonts in the Audio player/browser, larger time display as well, VIS is a "video" button, and some other tweaks that fit my needs - like Green/Red fonts to match my dash and interior lights (buttons/switched) at night -You GOTTA love the Skin Editor for RR - It's some good shizz - pics just posted -
    Crappy pics -
    車コンピュータ 3.0
  5. #35
    Jan 2005
    Latest addition: A Powermate knob for volume control - I positioned it close to me for easy reach - it's safer than constantly reaching over to the screen in my opinion - However, there are times where it won't work coming out of hibernation... I have to unplug/plug it back in order for it to work again... any suggestions?? Besides that, works great!
    I'll post pics...
    車コンピュータ 3.0
  6. #36
    NYC
    Im sending a hit out on u, so watch ur back. This ain't right!
  7. #37
    Jan 2005
    LOL - Erik, Thanks man!!
    車コンピュータ 3.0
  8. #38
    Oct 2004
    NY
    hey fray, I've had a few usb periferals that either interfeared with boot, or not come back from hybernation.. my solution is what I call a usb break...
    I use a small pcb relay to interupt the offending device either with a momentary switch that's used like a reset, or a toggle that can serve as off & on... some devices may just need to break & restablish one of the 2 data lines, & some may want the power broken too to reset the device itself.. there are dual throw relays, & there are relays that can do several resets at the same time... you can also rig up a time delay so that periferal connects say 10 seconds after the pc comes on, all automatically too...
  9. #39
    Maximum Bitrate BarryWoods's Avatar
    May 2006
    Ohio
    Quote Originally Posted by turbocad6 View Post
    Yea, but you're like the "Martha Stewart" of mp3car. You're building a car-pc but first you start off with a pile of sand to custom grow all the processors. Then you'll need some lead and silver to mix up the solder.........
    Failure is not an option....
    It's installed by default on every version of Windows.
  10. #40
    Jan 2005
    It's funny, I've been thinking about some sort of a cut-off/turn-on switch, but didn't know what to use for a USB cord...
    車コンピュータ 3.0
  1. Ford Mondeo CarPC!
    By jeroenvw in forum Show off your project
    Last Post: 12-31-2012, 09:50 AM
  2. 2004 Ford F350 CarPC
    By takissd in forum Show off your project
    Last Post: 08-31-2007, 09:14 PM
  3. ford escape / mazda tribute images needed
    By schaefer72 in forum General Hardware Discussion
    Last Post: 10-10-2006, 08:22 PM
  4. Fabricating an in-dash lcd in a Ford Escape
    By jmill in forum Fabrication
    Last Post: 08-23-2006, 09:18 AM
  5. Lekan's Ford Escape 2005 - CarPC
    By LekanB in forum Show off your project
    Last Post: 03-07-2006, 03:26 PM
