Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 51
Thread: First Ford Escape XLS with CarPC -
  1. #41
    Variable Bitrate afterdigital's Avatar
    Aug 2006
    New Ro, NY
    Quote Originally Posted by Fraychild View Post
    Latest addition: A Powermate knob for volume control - I positioned it close to me for easy reach - it's safer than constantly reaching over to the screen in my opinion - However, there are times where it won't work coming out of hibernation... I have to unplug/plug it back in order for it to work again... any suggestions?? Besides that, works great!
    I'll post pics...
    i have the same problem with my DVD/RW unit if i leave it plugged in.
    i never thought of doing what Turbo Suggests but definitely sounds like a good idea.
    CTS 05, Mobile Information Center...
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    5.6" Screen (overhead) w/reverse capability
    Finished Project
    Car Hacking
    WorkBlog
    Video
  2. #42
    Variable Bitrate Fraychild's Avatar
    Jan 2005
    Somewhere I Belong ~
    Updated Pics as promised:
    Thanks for looking!!
    VER. 3.0- Check out below:
    車コンピュータ 3.0
  3. #43
    Aug 2006
    New Ro, NY
    haa! that's sweet!!!
    hey how you like that knob thin-a-ma-jig??? I want to get one,but am not sure of it's purpose or practicality?
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    Finished Project
    Car Hacking
    WorkBlog
    Video
  4. #44
    Jan 2005
    Ha ha ha- Thing-a-ma-jig - LOL
    It's a Griffin Powermate, also available in Black (which I originally wanted) - It has a multitude of uses depending on which Apps you're running... however, I'm using with RoadRunner as a Volume button... It helps me raise/lower it when I turn the knob and it also helps me mute the music when I "press it down"... It works great - aside from the random times it won't work when I come out of hibernation, I would recommend it to anyone!!!
    車コンピュータ 3.0
  5. #45
    Aug 2006
    New Ro, NY
    hey fray,
    your touchscreen - is it a 7" or 8"?
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    Finished Project
    Car Hacking
    WorkBlog
    Video
  6. #46
    Jan 2005
    It's a 7" Xenarc - but boy how I wish I had an 8".... I was thinkin' about that new Lilliput, but the thought of removing and re-working the dash isn't that encouraging -
    Does anyone know if those have the "auto turn-on" feature???
    車コンピュータ 3.0
  7. #47
    Aug 2006
    New Ro, NY
    uhh? "auto-turn on"????? sounds like something i want on my LCD...explain...
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    Finished Project
    Car Hacking
    WorkBlog
    Video
  8. #48
    Jan 2005
    Auto Turn-On -
    You don't have to hit the power button to turn on the monitor, it automatically turns on when power is applied to it -
    Not sure about every monitor out there, but I know the Xenarc comes with that standard...
    Also some newer versions of the Lilliput monitors... but you have to do some "software" modification to make that work... Older models needed wire soldering for auto turn-on...
    車コンピュータ 3.0
  9. #49
    Jul 2006
    Another couple of quick questions...
    1) What did you use to affix the components to the lower center cubby?
    2) what position do the plastic screws have to be in to remove the lower central cubby?
    Jan 2005
    The components are held down by screws, some epoxy glue and some velcro (cushion) - Not sure what you mean by the position of the plastic screws, but they come out like regular screw using a screwdriver....
    車コンピュータ 3.0
  1. Ford Mondeo CarPC!
    By jeroenvw in forum Show off your project
    Last Post: 12-31-2012, 09:50 AM
  2. 2004 Ford F350 CarPC
    By takissd in forum Show off your project
    Last Post: 08-31-2007, 09:14 PM
  3. ford escape / mazda tribute images needed
    By schaefer72 in forum General Hardware Discussion
    Last Post: 10-10-2006, 08:22 PM
  4. Fabricating an in-dash lcd in a Ford Escape
    By jmill in forum Fabrication
    Last Post: 08-23-2006, 09:18 AM
  5. Lekan's Ford Escape 2005 - CarPC
    By LekanB in forum Show off your project
    Last Post: 03-07-2006, 03:26 PM
