Page 1 of 6 123456 LastLast
Results 1 to 10 of 51
Thread: First Ford Escape XLS with CarPC -
    Variable Bitrate Fraychild's Avatar
    Jan 2005
    Somewhere I Belong ~
    Talking First Ford Escape XLS with CarPC -
    NEW PICS ON PAGE 3!!
    Okay - let me clear this up - First XLS model with a CarPC, not the first Ford Escape - - Don't shoot me!!
    Anyway, after months of gathering parts here and there - and contemplating whether or not I should do a Carputer in my new truck, I finally decided to put something together to satisfy my basic needs when I'm cruisin' to work or taking long trips with the family -
    Specs are simple -
    Molded Xenarc 700TSVB Touch
    VIA SP13000
    Crucial 512GB RAM
    Maxtor 60GB HDD
    Slim Optical Drive with IDE adapter
    Opus 150 PSU
    RoadRunner Front End
    BU-353 GPS Receiver
    IGuidance 3 Navigation
    4-Port USB Unit
    That's all for now - I could have more pics up when I do some updates - Thanks for checking it out - Any comments or feedback is appreciated -
    Next will be details about the Audio setup -
    VER. 3.0- Check out below:
    車コンピュータ 3.0
    Variable Bitrate 4u2n's Avatar
    May 2004
    Denmark
    very nice install
    Plan for project = 100%
    Part the project. = 100%
    Built...................= 99%
    Finish.................= 99%
    Install ...............= 99% -50%
    Ditail at 4u2n.dk
    Here
    Jan 2005
    Thanks!!!
    I've it for a lil' while now... I just finally decided to stop being lazy and take pics of it to share with everyone..
    車コンピュータ 3.0
    Apr 2006
    Cincinnati OH
    looks great. i have a 2001 that i am hoping to do at some point.
    what did you do for the screen? it looks like you didn't have to modify the dash in any way, and that is my goal. appreciate any info you have on that
    thanks
    craig
    Jan 2005
    Actually, the dash was modified quite a bit, but from behind the center console - unfortunately, I didn't take any pics of that part of the project - but it's mounted tightly and securely so I wouldn't have to go back there again after I buttoned everything back up -
    車コンピュータ 3.0
    Oct 2006
    at speeds over 120 mph you might have some problems with the antenna
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    looking good, since you asked for comments and feedback: I really think you dropped the ball on the cd rom drive and usb hub. you have a perfect spot for it right under the screen. if you put it there (and make it look as good as your screen does) then you'll have an A+ install in my book.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Jul 2006
    I know you said you don't have any pics of the screen install, but in general, how did you do it? Specifically, how did you work around the metal ring that the factory head unit uses to stablize itself? I would think that if you mount the screen with the housing flush against it, that it would pertrude in such a way as to make the radio bezel not mount flush anymore. Inquiring minds want to know!!!
    Constant Bitrate soundoff's Avatar
    Jul 2004
    AUSTRALIA
    GPS doesnt move in that position?
    I am considering putting mine in the same spot.
    also you havnt had any trouble with water in the GPS unit? I am scpetical of the "waterproof" rating on the GPS after the number of BU-303's that failed from water damage
    Oct 2004
    NY
    hey fray, nice job
  1. Ford Mondeo CarPC!
    By jeroenvw in forum Show off your project
    Last Post: 12-31-2012, 09:50 AM
  2. 2004 Ford F350 CarPC
    By takissd in forum Show off your project
    Last Post: 08-31-2007, 09:14 PM
  3. ford escape / mazda tribute images needed
    By schaefer72 in forum General Hardware Discussion
    Last Post: 10-10-2006, 08:22 PM
  4. Fabricating an in-dash lcd in a Ford Escape
    By jmill in forum Fabrication
    Last Post: 08-23-2006, 09:18 AM
  5. Lekan's Ford Escape 2005 - CarPC
    By LekanB in forum Show off your project
    Last Post: 03-07-2006, 03:26 PM
