Originally Posted by
Homebrew
Is it bigger or smaller than the double din kit? Either way I don't think it's an easy fix. Not impossible, just not a quick fix. If the opening isn't large enough, trying to enlarge the opening while keeping the cuts straight would be difficult. You'd likely have to go back with filler to clean it up. If the opening is too big, shrinking would just be a matter of adding some more plastic and then using filler to clean up the seams. However no matter how good a job you do, adding material will, in my opinion, look a little odd. I'm guessing though that the problem is that the opening needs to be enlarged. I would probably just cut out a large enough opening to mold the lilliput bezel in. I'd really need to see the parts to offer a decent suggestion.
-Kevin
