Ok and Now the Balls!
My buddy and I came up with a shelf system to go in the rear cavity. The Amp is on the bottom w/ 2 hdd drive fans that blow inside the cavity. The 2nd level is for my HDD and PSU. On this level there is a horizontal fan (from an old PowerSupply) that blows the air up. The third level is for the mobo with a blower to push all that no good hot air out of the cavity. All the materials to make the shelving and front cover was 3/4" smoked plexi-glass.
This is a little off topic, but I would like to show it off. I made my first fiberglass sub box. It holds an 8" SoloBaric with an MTX rt251d (about 300 watts):
This part doesn't really make the box look good, but I wanted to show how it's integrated with the vehicle. I put washers where the seat belt bolts go. It's not going Anywhere!
Well thanks to everyone for all the help....you probably don't know it, but you most likely helped me in some way. Okay Dokey![]()
LinkBack URL
About LinkBacks
, and that sub box is nice, but it can be smoothed out, just takes time, I say invest it, it will be worth it.
