Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 57
Thread: 2003 VW GTI 20th AE Work Log
  1. #11
    Elsewhere
    Moved to SOYP.
    How about the Wiki?
  2. #12
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    looking good, how do you like it?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  3. #13
    Nov 2006
    it works quite well, dispite some glitches, im working on fixing them
    :glitches
    - right and left channels cant be on at the same time, ground loop though y ( need something that allows voltage to only go one direction, not sure what its called )
    -slight fuzzyness, might need a ground loop isloator
    -posable overheating ( might move computer to trunk )
  4. #14
    Nov 2006
    i was able to fix the problem with the ground loop causeing interfearance, and the left channel cutting the amp power, all with a ground loop isloator. i didnt need to put in a diod. i saw that other people with the monsoon had the isloator cut in after the 5-6v was indused, but i put it in befor, and i dont have any noise. also didnt have to "cut" anything.
  5. #15
    Nov 2006
    some new pics just taken a few min ago
    the monsoon connector and ground loop isloator
    hidden inside
    driver seat, car off
    car on at desktop
    car on running roadrunner (for music)
    roadrunner home
  6. #16
    Nov 2006
    i just got the wires and USB hub to move everything to the trunk, haveing the computer behind the screen was a bad idea, it made the computer compleatly inaccessable, and it overheats, and when the comp hits 60c the comp freezes, and wont go back to normal untill i restart the car and wait 45 sec
  7. #17
    Nov 2006
    i moved everything to the trunk. when it was behind the screen, with a crapy heatsink, the computer was prone to overheating.
    i moves the monsoon amp to where the cd changer normaly goes and mounted the computer where the amp normaly goes
    here are some pics
    this is befor i put any wires on it and befor puting it into the car
    ther computer is mounted and redy to go, i still need to do some more wireing, but for the most part the trunk is refnished.
    now you see it
    now you dont
  8. #18
    Constant Bitrate Perrosky's Avatar
    Feb 2006
    NJ
    Nice install what skin are u using?
    One of the best way to learn is making mistakes, But much better when you learn from someone else mistakes
  9. #19
    Constant Bitrate stangg172006's Avatar
    Jan 2007
    Morton Grove, IL (Northside Chicago)
    great install man! i have an 06 black rabbit am looking to do the same thing. thanks for the reference material
  10. #20
    Dec 2006
    Boston
    Like the install and the little compartment where it's in the trunk. Good job.
    "Life doesn't forgive weakness."
    2001 Mitsubishi Galant ES - 5 Speed Conversion/KYB AGX/Tein S-Tech/Addco Rear Swaybar/Injen CAI/Megan Catback Exhaust
    CarPC [----------] 30% Complete
  1. 2003 VW GTI Worklog!
    By pogitalonx in forum Worklogs
    Last Post: 02-12-2008, 03:03 PM
  2. EZSync work on Windows Server 2003?
    By urosbe in forum EZSync
    Last Post: 01-08-2006, 11:22 AM
  3. Replies: 0
    Last Post: 09-02-2005, 03:12 PM
  4. Prison vs Work
    By ACHIEVER in forum Off Topic
    Last Post: 04-15-2005, 02:53 PM
  5. Replies: 3
    Last Post: 04-09-2003, 11:48 AM
