Walmart has a $30 hydrolic jack that's 4" and one that's 3.3" for about $60.
1999 Black Pontiac Trans Am
CarPC's in F-bodies
How To Relocate Climate Controls on the 97-02 F-body Cars
(AMD Sempron 3000+, Opus 150)
Car PC system is out, Alpine system is in.
The cheap jack is small and comes in a case. It's actually 3 1/2" but looks more like 3.75 for some reason. But I have a pocket size multipurpose tool that fixes anything. It's a cell phone.
So how low does the stock tire jack go anyway? I've never used it.
It works great. Goes down to about an inch or so.
CarPC's in F-bodies
gezz Jason, i didn't know that you had to carry blocks, i hope you've never had to use them before lol.
I acquired this yesterday.
no power supply and when i got it hooked up the backlight was out. with a quick reseating of the 4 backlight pins and a couple cold solder fixes i was up and running tonight. I've been thinking more and more about doing a rear seat install that came strait forward to the front seats at the same height and my floor in my trunk. I think it'd give the back of my car the look kind of like a magnum. I then was thinking about flush mounting the subs up towards the front seats (maybe angle them towards the back) because i know Jasons test show that there is a gain from them pointed towards the rear window in F-bodys. I was thinking i could take this monitor and motor it up just behind the subs, so it could go all the way in the new "floor" i would then stick my 3 amps across the spot where my box is now. If i did this i would also change my interior over to ebony (black) and get my neighbors black seats that he's replacing in his '06 Tiburon they are these (stock photo)
to show the insert pattern
Any thoughts? I'm not sure if i'll like this because i've been trying to keep it stock looking and i'm not sure if i want pull all this off with it still looking stock. Do you guys think it would look out of place with the back all one height or help with the flow and making it hard to tell it didn't come like that? I guess i just have too many ideas rolling around in my head![]()
1998 Camaro Worklog Starting over, New setup for 2010
I use them all the time. It's no big deal. Some tire alignment racks are too steep so I use them there. The lifts that have 4 arms I used to have to drive all 4 tires onto one block each to get the arms under it. If you get a flat at home where you have a hydrualic jack I just stack 2 blocks and drive the flat tire onto them. Even with the factory jack you can drive onto a block or two to speed up the lifting as you don't have to crank on the jack forever to get it high enough. They come in very handy. I just cut a 2x4 into 4 18" long pieces and then cut the end at a 45* angle.
I don't want to get too far off topic here.
CarPC's in F-bodies
no ones interested in giving me their suggestions.... lol oh well
Right now i'm in the process of switching over to Linux from Windows because i believe there is so much to gain in the future from Linux. With this I'll be doing a upgrade on my motherboard and cpu. Right now i have it running on my desk and I hope to get the latest version of nghost running and maybe within the next week make the switch.
I still need to find a Driver for my x-box controller and a hotkeys program.
Ubuntu 7.01 Feisty - OS
nghost - Frontend
Dell Gx60 - Motherboard
2.0Ghz Celeron - CPU
512mb - Ram
laptop tray load cd drive for rear
I'm having a hard time understanding what your describing with the rear seats and such.
CarPC's in F-bodies
I'm thinking about taking out the back seat and making and enclosure to take up the whole rear seat from side to side and make it appear to be a 2 seater. I'd make the box flush with the floor just above the gas tank (where my box is sitting) With this design i could flush mount everything and have it look very plain and OEM (with any luck).
was this a better explanation?i could barely read what i wrote before lol
When you showed a picture of a different back seat I assumed you were wanting to install it in your car. Why did you show that picture? The front seats look pretty good from that Tiburon. Since you have a camaro your seats don't have the big side bolsters the TA's do so I imagine it would be a big improvement as far as keeping you in place.
Once you move the subs to the back seat area you lose a lot of output. Now if you put them in the far rear area the output would really good. Do you want it to look something like this?
CarPC's in F-bodies
